285/75R16 on a 2012?
Discussion in 'Wheels & Tires' started by Utard, Nov 5, 2011.
  1. Nov 5, 2011 at 7:46 PM
    Utard
    Utard [OP] Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Hi all. First post. I did search but that was no help. My 2012 came stock with 265/60 18. I am looking at getting the factory TRD bead lock rims (16") as a second set for off road use only. I am thinking of the Goodyear Wrangler MT/R with Kevlar. They do make a 265/75R16. I do not plan on lifting this vehicle. I do not plan on doing any real wheeling with this since it is my work truck. It always seems like you can go with one size over stock with out problems so I was thinking of the 285/75R16. This will only add 1/2 inch per side width and radius over stock. Any 2012ers tried a 285? I will not do any trimming so I do not want any rubbing. Thanks.
  2. Nov 5, 2011 at 7:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You need 2 1/2" of lift , wheel spacers , lose the mudflaps and trim the inner fender to run 285's
  3. Nov 6, 2011 at 6:32 AM
    Utard
    Mark
    Nyssa, Oregon
    Anyone put a 285/75R16 on a unlifted 2012? Any rubbing?
  4. Nov 6, 2011 at 6:39 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    You are probably a bit too early with the 2012's to get an answer. However since Toyota did not change the suspension or the fenders other then near the headlights you situation would be the same as any owner from 2005 on. Unfortunately the answer is no. You need a lift, wheel spacers, and some trimming as posted above. If you do not want to lift it then a whole bunch of trimming and you will still need wheel spacers otherwise it will rub on the frame, UCA, and LCA.
  5. Nov 6, 2011 at 2:00 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Read reply the guy took the time to post.
    Firebird likes this.
  6. Nov 6, 2011 at 2:18 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    :wave: Utah welcomes you to TW. Congrats on the 2012.
  7. Nov 6, 2011 at 2:19 PM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    Like he said, no way to run 285's without modifications.
  8. Nov 6, 2011 at 2:21 PM
    jdhaas3
    jdhaas3 Well-Known Member
    Jimmy
    Virginia
    Jeep Rubicon
    Durango front bumper, Warn Dual Force Powerplant HP winch with synthetic line, 3.5 AE lift, regeared to 4.88, ARB diff cover
    i have a 3 inch toytec lift and i am running 285/75r/16, no trimming required...you get ver minimal rub only at max turn...this is on an 11 though
  9. Nov 6, 2011 at 4:34 PM
    JasoTaco
    Without a lift the biggest you can run is a 265/75/R16. No trimming.
  10. Nov 6, 2011 at 4:39 PM
    OZ-T
    Peter North
    British Columbia
    Or 255/80/16
  11. Nov 6, 2011 at 4:55 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Why do you want the TRD beadlocks for off roading? You know they are fake beadlocks, right? Its a waste of money, just get a cheap set of steel wheels.
  12. Nov 6, 2011 at 6:30 PM
    JasoTaco
    True, those Toyota wheels are way too expensive to beat up on the trails. If you want a second set of wheels to beat up watch the classifieds on KSL. I saw a set of TRD wheels / tires on there for $200 today.
  13. Nov 6, 2011 at 7:49 PM
    Utard
    Mark
    Nyssa, Oregon
    I don't know why I always forget to check KSL? There are some great deals on there.
  14. Nov 6, 2011 at 7:50 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    It will run as shit!
  15. Nov 6, 2011 at 8:03 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Ya, thats what im rolling on and lots of room. My 255/85/16's have more clearance than the 265/75/16'S BFG T/A KO's. Had just a little rub on the driver side mud flap at full turn (ya people with a 3" lift) no clue Y.
  16. Nov 6, 2011 at 8:06 PM
    Mr.Ed
    Wilbur's Barn
    Sorry I'm rolling on 255/85/16"s now. and the 265/75/16's did not rub with out a lift. Just goes to show ya. I kept thinking it was the lift klunking untill I pulled the wheels to put on the new rubber.
  17. Nov 7, 2011 at 6:45 AM
    Utard
    Mark
    Nyssa, Oregon
    English buddy? Thats all I speak.
