285 AIR PRESSURE
Discussion in 'Wheels & Tires' started by Fire Taco Fighter, Feb 15, 2014.
  1. Feb 15, 2014 at 8:44 AM
    Fire Taco Fighter
    Fire Taco Fighter [OP] Well-Known Member
    trd
    For those of you who run 285's on their truck what air pressure do you have.
    My tire says 65 max.i had 60.....Toyota told me to run 35. I think that's under-inflated.
    What do you guys do?
    Otto
  2. Feb 15, 2014 at 9:01 AM
    vssman
    vssman Rocket Engineer
    Naugatuck, CT
    2013 SR5 double cab
    I'd bet 35 is closer to the right reading. 65 is way too much. That's the max psi if you're running the max load on the tire. Take some chalk and put lines across the tread around the tires. Run the truck around the block. Stop and look, let air out a few psi at a time until the chalk is evenly removed.
  3. Feb 15, 2014 at 9:02 AM
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    I run 50 psi. Little stiff but noticeable gas mileage improvement
  4. Feb 15, 2014 at 9:12 AM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Safety Meeting
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    on the street I run about 40psi
  5. Feb 15, 2014 at 9:19 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    07 TRD OFFROAD 4x4 VSC/TRAC/DAC/HAC
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I run 35 psi on load range e tires with no load in the bed (tires have a max load psi of around 80 psi.) If your running yours at 60 psi they're going to wear in the middle (over inflated.)
  6. Feb 15, 2014 at 10:17 AM
    Fire Taco Fighter
    trd
    Ok great thanks guys..I'm gonna do the chalk thing.......Rt now I am running 44.
  7. Feb 23, 2014 at 1:37 PM
    BluntTaco
    BluntTaco Tight and Right
    Randy
    Centreville, MD
    09' Taco 4x4 TRD Sport
    Undercover, Pioneer AVIC Z130BT, Toyota Roof Rack, Drop in aFe. Camburg UCA's, Toytec Ultimate 5100 Kit, OME Dakar Rear Kit, Custom Mayhem Grill, Wicked Muff w/tip, Some Debadging.
    I was running 35 psi, then went to 40 psi, now at 48 psi. Looking for some MPG gains but haven't really seen a difference. When I went to the 285's I saw a drop of 6 mpg! It has also been in the 20's since with winter blends so I'm hoping that will improve. I also have not taken into account the fact that my Odometer is going to be slightly off, gonna try and get a GPS reading of mileage with the next tank.
