285 question
Discussion in 'Wheels & Tires' started by Snake~, Apr 11, 2013.
  1. Apr 11, 2013 at 6:50 AM
    Snake~
    Snake~ [OP] Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    So if my truck has 5100s at 2.5, wheels with 5" backspacing/15mm offset and I do zero off-roading, will 285s work without the cab mount chop? My mud flaps are already removed and I don't mind doing a little trimming but I don't want to mess with the cab mount chop. I'll stick with 265s if that's needed.
    Also, would tire size in combination with 5100s at 2.5 effect whether I would need new UCAs? Would the extra sidewall height effect that or just the lift height?
    Muchas gracias
  2. Apr 11, 2013 at 9:09 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Blake, are you a Kiwi perchance?
  3. Apr 11, 2013 at 9:22 AM
    DevL
    DevL Well-Known Member
    285 is a width. Your question cannot be answered without a height. Its like asking if you can use just a quart of paint to paint a hallway that is 6 feet wide. Tire size has zero effect on whether UCA is needed. You can always not use an UCA that adds caster and have sketchy handling. If you add it though it moves the wheel rearward and increases the likelyhood of rubbing. Also saying no wheeling implies you accept some rubbing... if you don't mind rubbing every time you enter a steep transition to a parking lot at speed with your wheel turned you could be ok with a set up others would consider unacceptable.
  4. Apr 12, 2013 at 6:53 AM
    Snake~
    Blake
    DFW
    2010 DCSB TRD Sport
    No sir, I'm a Texan.
    285/70-17
    And this is just for looks. The only thing close to off road driving I do is the occasional dirt road. I like the looks of 285s on Tacomas but I wasn't sure if 2.5" of lift would be enough. Too bad there aren't more choices in the 275/70-17 size. That would probably be perfect.
