285 vs 315 Why one over the other?
Discussion in 'Wheels & Tires' started by thegreatwall23, Dec 28, 2012.
Which would you pick?
Poll closed Jan 27, 2013.
  1. 285/70R17
    20 vote(s)
    52.6%
  2. 315/70R17
    18 vote(s)
    47.4%
  1. Dec 28, 2012 at 7:52 AM
    thegreatwall23
    thegreatwall23 [OP] Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    A couple of questions on this... First, let me say that I have a front bumper, lift, CMC, Icon tubular ucas, 4.56 gears, etc... So, I am not that concerned with it fitting. I have had 305's and had no issues. With that being said, the 305's wheels had 5 backspacing and 0 offset. Do you think a 315/70r17 would rub the uca with 4.5 backspacing and -12 offset?
    Second question... I have read why many people like a 285 or 315 over the other. Most of the time it comes down to not being able to fit the bigger one, or the narrow one is better in the snow, wider is better in the mud, the list goes on and on. So, if fitting the tire under your truck wasn't an issue, which would you pick and why? Why is one better than the other?
  2. Dec 28, 2012 at 8:00 AM
    alnewt1234
    alnewt1234 Well-Known Member
    Alan
    Texas
    TForce
    I have 285's and that is because that is the biggest tire that would fit. I wouldn't go any bigger if I could tho looking back on it. I personally don't have any need for larger tires than that and kills the gas mileage and makes the truck work harder.
  3. Dec 28, 2012 at 8:20 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The short answer is that once the suspension is fully compressed, the wheelwell isn't any bigger than it was from the factory - unless you made it bigger by cutting. Now, with a stiff aftermarket lifted suspension, this is unlikely to happen on the street; as opposed to the stock suspension which is pretty easy to hit the bump stops on the street. But full stuff can and does happen off-road.
    A 33x11" tire needs about 1" extra clearance all the way around.
    a 35x12" tire needs about 2" extra clearance all the way around.
    So everyone picks their combination of
    * cutting (including cab-mount-chop, pinch weld, etc...)
    * rubbing (often unnoticed, least of your worries when you've driven into a really hard hit)
    * not driving to stuff the wheels (milder driving style or milder terrain)
    Pick your poison man. It sounds like you want the 315s and I'm not going to try and talk you out of them.
  4. Dec 28, 2012 at 8:51 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Meh stuffing 35's isn't all that hard, these are quite a bit bigger than a 315/70r17 too
    i used to have a 6" lift and 33's, now i have a 3" lift n 35's and tackle stuff i never would have imagined doing with the 6" and 33's. the 35's have treated me very well off road!
  5. Dec 28, 2012 at 9:06 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Im rubbing horribly in turns with 315's I need to beat the pinch weld into submission some more.
  6. Dec 28, 2012 at 9:14 AM
    PLC721
    Patrick
    Chandler, Az
    how much have you trimmed?
  7. Dec 28, 2012 at 10:32 AM
    J88logue
    J88logue NorthWest Member
    Jonnie
    HWY 30
    02 D.C. TRD LIM. F.T.W.
    Clicko BUILDo
    lol why one or the other...Really...well i'm here anyways....
    one is heavier = less power, lower gas mileage.
    one has 1" more clearance = better ground clearance.
    One is wider = not enough to matter.
    One is more expensive = less TacoBell money
    One is smaller = less possibility of rubbing/more clearence.
    It should be completely obvious why one would want one of the other, the answer if nearly in the question. Best of luck to you ;)
    BTW i run 285s
  8. Dec 28, 2012 at 10:37 AM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    yeah, I know all of the obvious ones, I just thought I would let people chime in and give their opinion and help me spend my money! lol... I have had 305's, then moved to 285's, thinking about going back up to 315's since I regeared.
  9. Dec 28, 2012 at 10:40 AM
    J88logue
    Jonnie
    HWY 30
    Clicko BUILDo
    Yeah you def could!
  10. Dec 28, 2012 at 10:41 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I don't think you'll fit them like you think you will
  11. Dec 28, 2012 at 10:50 AM
    PLC721
    Patrick
    Chandler, Az
    oh yeah, you have to accept the fact a saws all will and grinder will be used on your nice Tacoma :)
  12. Dec 28, 2012 at 12:16 PM
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    hum... Do you have any rubbing or issues? What kinda of issues do you see me having? Like I said I have run the 305's and I had no rubbing anywhere, but I did have a very deep cab mount chop and pinch weld job done and some trimming on the fender flares. The new tires according to the tire calculator would be .75" taller and .3" wider. I just don't see how it would be too much different.
    Thanks for your input! I need to make sure I am not missing anything.
  13. Dec 28, 2012 at 4:23 PM
    nfs257
    Noford I have the cab mount chop and tube bumper and fiber glass. I just need to beat the pinch weld.
  14. Dec 28, 2012 at 5:34 PM
    PLC721
    Patrick
    Chandler, Az
    Hmm how much lift?
  15. Dec 28, 2012 at 9:08 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Are those glass fenders? I certainly can't see the stock front fender flares in that pic and there aren't any fender holes.
  16. Dec 28, 2012 at 9:10 PM
    PLC721
    Patrick
    Chandler, Az
    No those are glass, even before glass i found most of the rubbing to be the pinch weld area and of course body mount
    AP Glass 2" rise 3" Flare
  17. Dec 28, 2012 at 10:51 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    And ohhh sooo sexy! :D
    I'm getting 35's next! You can play with getting enough caster to push the wheel forward as to not rub the firewall (pinch weld area) but the pinch weld will need to be flat and cab mounts chopped to give an extra inch or so in that area! You will deff need glass fenders or trim a few inchs off the stockers since the up travel will also be an issue!
  18. Dec 29, 2012 at 9:33 AM
    nfs257
    4" lift spindles and kings lifting about an inch or 2.
  19. Dec 29, 2012 at 10:49 AM
    TacTRDFreak
    TacTRDFreak Dave
    Dave
    Southeast Texas
    2008 PreRunner
    3/2 lift skid plates 17" wheels oversized tires, hid headlights and fog lights, Pioneer system with iPad rear video for the kids. Modified air flow with K&N filter and all Royal Purple Synthetic fluids
    Have an 08 with 3/2 suspension lift. How far oversize can I go on tires without rubbing?
  20. Dec 29, 2012 at 10:58 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    35's because I can :D with alot of cutting, trimming, cab mount chop (twice).
