2857017
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bsb103, Mar 11, 2019.
  1. Mar 11, 2019 at 7:15 AM
    Bsb103
    Bsb103 [OP] Member
    B
    2016 grey Tacoma
    Lift and rims
    any one run 2857017 with bilstein shocks and ome coil without doing cab mount chop ?
  2. Mar 11, 2019 at 7:16 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yeah...but most rub
  3. Mar 11, 2019 at 7:23 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    you'll rub. pretty much a guarantee. what offset are your wheels? any spacers. I'd say 95% people rub the other 5% don't do any offroading.
    One thing to remember that suspension has nothing to do with tire fitment. (bracket lifts excluded). If your lifting by preloading your coils, your travel lengths are exactly the same as stock. So if you can't fit your tires on stock suspension setup your not going to on a preload lift. The only other exception may be a spacer lift because similar to a drop bracket your moving everything down. But if your offroading on a spacer lift your chances of having a bad day increase ten fold.
    Stocklocker likes this.
  4. Mar 11, 2019 at 8:50 AM
    Bsb103
    Bsb103 [OP] Member
    B
    2016 grey Tacoma
    Lift and rims
    I have scs wheels 17x8.5 4.30 bs
    I running that size tire now but with 3in leveling kit and it doesn’t rub at all
  5. Mar 11, 2019 at 8:52 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Even when flexed?
