285s on 1.7 in lift front
Discussion in 'Wheels & Tires' started by RaminMan, Dec 26, 2023.
  1. Dec 26, 2023 at 10:40 PM
    RaminMan
    RaminMan [OP] Well-Known Member
    Littleton Colorado
    2020 Super White Tacoma TRD Off Road
    Hey all, I am looking to upgrade to some 33's(285 70 17) since recently I just put on a 1.5" lift rear and a 1.7" lift front. Currently, I'm running 31.7(265 70 17). I've looked everywhere for people running a similar setup but have only found Fokes running 2" lift systems.
    Just curious will a 1.7" lift be able to accommodate them?
    Thanks!
  2. Dec 28, 2023 at 7:32 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    The main question you face to fit 285 in the front and back of your front wheel well, is how much negative offset, if any, you have or will have. See article below.
    The 1.7" lift helps but is less impactful than how far out your tires stick.
    I have no lift and still got nearly 1/2" forward caster adjustment when I asked the shop to max forward my alignment.
    https://***************/2021/06/08/fit-33-tires-285-70r17-stock-3rd-gen-tacoma/
    908tacoma likes this.
  3. Dec 28, 2023 at 1:59 PM
    nckg
    nckg Well-Known Member
    Any idea if zero offset TRD style wheels would fit 33s on the same lift setup?
  4. Dec 29, 2023 at 10:33 AM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    In the trailtacoma article, the had stock +30 mm offset wheels. They added a 3/4" spacer, which is -19 mm of offset, leaving +11 of effective offset. In the article, they go through the trimming they did to fit Yokohama Geolander 285/70r17 tires- they appear to be AT models. See manufacturer tire dimensions for that size and model.
    Personally, I have 305 width tires and -6 offset wheels on my unlifted truck, and I got a cab mount chop and trimmed about 3/8" from the front and back bottoms of my front wheel wells for more turning clearance.
    Zero offset with a 285 tire may work without the chop or trim but it is a small window to work with
  5. Dec 29, 2023 at 10:40 AM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Aftermarket UCAs help, but are not always necessary. Wheel offset is more important than lift. 0 offset or -6 seems to be a nice spec on an 8 inch wide 17 inch wheel
  6. Dec 29, 2023 at 1:29 PM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    The truck in article was fitted with Geolander X-ATs. 33.0" diameter, 11.7" overall width.
  7. Dec 29, 2023 at 1:35 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Anything will fit if you're willing to do the work :notsure:
  8. Jan 2, 2024 at 12:10 PM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    I am running 285/70/17s on a 1.5" spacer. -12mm offset wheels. No rubbing.
