285s on 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco, Feb 10, 2016.
  1. Feb 10, 2016 at 4:57 AM
    12taco
    12taco [OP] Cement to be
    Hunter
    Chattanooga, TN
    2018 Double Cab TRD Off-Road 4x4 Cement
    LED turns, brake, & reverse lights
    Ok I'm not finding much. I am putting a 2.75" front and 1" rear lift on my 2012 ACSB with LR UCAs and I'm wondering if the 285/75/16 BFG KO2s will fit without major rubbing. I am not doin a cmc or cutting any metal but I wont be rock crawling heavy mudding or anything too big this is a daily driver i want to be able to drive through some mud goin hunting and if they rub a liitle at full lock thats fine cause that hardly happens. Will these tires cause a problem? also know that my mpgs will go down a little.
  2. Feb 10, 2016 at 7:51 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    I have a 3" lift with and I'm running 285/65R18's with no rubbing. I removed my mudflaps and that's all.
    12taco[OP] likes this.
  3. Feb 10, 2016 at 9:39 AM
    12taco
    Hunter
    Chattanooga, TN
    Awesome! Thanks
  4. Feb 10, 2016 at 9:41 AM
    spacecat
    spacecat Well-Known Member
    Lauren
    So Cal
    03 White 3.4L V6
    I have a 3in lift with 285/75/16 BFG KO2s
    and they only rub when fully locked to the right
  5. Feb 10, 2016 at 9:58 AM
    Drew_05Tacoma
    Drew_05Tacoma Well-Known Member
    Drew
    Unionville, NC
    2008 Access Cab Tacoma 4x4
    Level
    285/65/18 No rub after trimming fenders on 3inch lift
  6. Feb 10, 2016 at 10:01 AM
    spacecat
    Lauren
    So Cal
    03 White 3.4L V6
    Did you trim em yourself? Is it easy?
    I've been considering trimming..
  7. Feb 10, 2016 at 10:04 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    3" lift on 285/75/16 no rub after trimming bottom fender plastic, removing mudflaps, a CMC, and flattening the pinch weld..I guess it depends on how you use it..
  8. Feb 10, 2016 at 12:48 PM
    Drew_05Tacoma
    Drew
    Unionville, NC
    Level
    Yep, just bought a cheap $30 Dremel tool, it was super easy.
  9. Feb 13, 2016 at 9:51 AM
    12taco
    Hunter
    Chattanooga, TN
    Ok i found that Nitto makes the Trail Grapplers in a 285/75/16 the inflated dimensions are 33.03/11.73/16 thats gonna be too big to not rub ain't it?
    they also make it in a 285/70/16 but its 31.89/11.50/16 i don't really want a 32
  10. Feb 13, 2016 at 9:57 AM
    geekhouse23
    285/75/16 will rub turned lock to lock and technically the 285/75 is a 32.8"
  11. Feb 13, 2016 at 10:01 AM
    12taco
    Hunter
    Chattanooga, TN
  12. Feb 13, 2016 at 10:10 AM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I have a 2014 and a 2015, both with 3" and 285s. Neither rub after clipping the inside rear flare a little, but I haven't done anything remotely hard-core with either. Alignment makes a big difference. Just make sure the front cam bolts are to the inside a little(to pull the tire forward) before you take it for an alignment. I do have LR UCAs on both trucks.
    geekhouse23 likes this.
  13. Feb 13, 2016 at 10:12 AM
    12taco
    Hunter
    Chattanooga, TN
    how do I adjust that I too will have the LR UCAs
  14. Feb 13, 2016 at 10:14 AM
    Jrozz
    Jrozz Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    i have 285/75/16 on my 3" lift. cut some plastic, nothing major
  15. Feb 13, 2016 at 10:16 AM
    12taco
    Hunter
    Chattanooga, TN
    Man i need to just get to this next pay check and get the lift and tires done so I can stop looking and thinking about changing which tire I want :annoyed: I'm getting BFG 285/75/16s
