285s on spare tire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimbo808, Sep 18, 2015.
  1. Sep 18, 2015 at 12:30 AM
    jimbo808
    jimbo808 [OP] Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    Hey guys just wondering if I could throw on a 285 on the spare tire and if it would rub on the ucas in the case that I actually use it? Anyone know if its the right offset/backspacing? I got the LR ucas with icons set at about 3 inches. Did the cmc and cutting already.
  2. Sep 18, 2015 at 2:10 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    On an OEM rim, it will rub on the front knuckles if no spacer/adapter is used. Will also rub on the wheel well plastic, even if you get the spacers/adapters. My 265 70 R17 tires rub even after I did some trimming at the corners.
  3. Sep 18, 2015 at 2:11 AM
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    I have the all pro rear bumper so my experience may differ depending on your setup. It will fit but you will need to do some mods back there. I had to bang the two arms open wider, cut off the last exhaust hangar (wasn't using it anyways), and relocate the trailer plug in. The tire rubs on the front for me, but I've got aftermarket wheels on the four that I use everyday. I can't answer the rubbing question if you're using spacers
  4. Sep 18, 2015 at 3:03 AM
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    thanks for the info, I'll throw on the spare wheel and guesstimate how much it'll rub with the wider tire. Also gonna try find an fj steelie or something similar on craigslist.
  5. Sep 18, 2015 at 5:36 AM
    Pigpen
    Dan
    Northwest Montana
    I'd get a fifth of whatever wheel you are running on the truck. The spare is meant for no wider than a 265. The 285 may be unusable when you need it most. Yes, it will fit in the stock spare location, but will rub terribly when you try to use it - unless you are running 285s on your truck with spacers and stock wheels.
  6. Sep 18, 2015 at 8:16 AM
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    I ended up buying a spare rim with the same offset as what I'm running and a 285 to hang under the truck. Steels will not work with the lift. Plus it nice having a full size spare.
  7. Sep 18, 2015 at 1:50 PM
    FATaco
    FATaco Meh
    Fairbanks
    07' TRD DCSB
    I wouldn't say unusable.... I've been in the middle of nowhere and had to wheel out using the spare. It rubs, but works in a pinch. 5 matching wheels is the best option if you got the cheddar, I just wanted to address the question as you asked it.
  8. Sep 18, 2015 at 2:05 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Get a 255 tire, you can find one close enough to the 285 size to use in an emergency. It also will not hang down low in the stock location, but the frame tabs holding it in place will need to be modified.
  9. Sep 18, 2015 at 2:06 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    no they didnt.
