285's on stock 16 inch rims
Discussion in 'Wheels & Tires' started by roberts white lightning, Jan 1, 2012.
  1. Jan 1, 2012 at 5:27 PM
    roberts white lightning [OP] Well-Known Member
    robert
    riverside
    07 speed way blue prerunner
    stock for now
    the search came up empty, but heres the deal. im picking up 285/75r16 bfg km2's, will these work on the stock rims??? i have a 2 inch spacer lift, and i know trimming will be done to the cab mount and all that but will the spindle and the frame be a issue?
    thanks
    robert
  2. Jan 1, 2012 at 5:32 PM
    robert
    riverside
    stock for now
    im willing to do spacers, i plan on running camburg spindles in the near future so i will need them for sure with the stock rims. i dont know why but i dont want to get rid of my stockers, i really like them :eek:
  3. Jan 1, 2012 at 5:32 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    They will fit on the rims but you will rub like a mother fucker... You will need wheel spacer as well as a lot of trimming of the plastics. I have the TRD Ivan Stewart rims and those have the correct backspacing and offset, yours do not.
    I rubbed on the front and back, had to trim a lot of plastic, rubbed on my cab mount and pinch weld. rubbed when flexing, when turning, etc...
  4. Jan 1, 2012 at 5:34 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    they wont mount with out wheel spacers cause your UCA will be in the way...I know cause it happened to me a while back...
  5. Jan 1, 2012 at 6:59 PM
    robert
    riverside
    stock for now
    So spidertrax will be getting a call in the near future.
  6. Jan 1, 2012 at 8:14 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    holy mother of god its bobert! :wave: i didnt notice you were in an 07 prerunner. hows the military.
  7. Jan 1, 2012 at 8:23 PM
    PEPCATCH11
    PEPCATCH11 Well-Known Member
    Dan
    Tulsa, OK
    2011 Regular Cab
    TRD skid plate, Bilstein 5100 struts @ 2.5", Bilstein 5100 shocks, Wheeler's 1.5" AAL, Spidertrax 1.25" wheel spacers, BFG KM2 285/75/16
    I have 285/75R16 BFG KM2's on the stock steel wheels with Spidertrax and Bilstein 5100's @ 2.5" and the fit fine with no rubbing.
  8. Jan 1, 2012 at 8:26 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    Check out the B/S/T thread a guy is selling 2 sets of spidertrax...
    Edit: Nevermind, they already sold... sorry
  9. Jan 1, 2012 at 9:43 PM
    jjudd
    jjudd Member
    Justin
    Temecula
    09 tacoma 4x4 longbed sport pkg
    3inch front 2 inch rear lift using spacers in front and add a leaf in rear
    Yeah you will for need spacers to clear the UCA's or different rims until u do the new spindles.
    I just put 285 70 r 17s on my stock 17 inch rims and they need a good amount of trimming and added the 1.25 wheel spacers with them. You may be able to get around that with a higher lift but I had a 3inch spacer lift and it was rubbing good on full turn. Not much trimming though and only the fender needed to be trimmed at the lowest point
    285 75's are going to be huge but looking nice once you make it work> I really wanted to do that route but the bfg at's rubbed good at the 285 70 and they have a less deep tread. Now I have to start all over as some lady without insurance tagged my turck after blowing a red light and over correcting.
    Good luck man! and if you order the spacers from spidertrax they will be there wihin 2-3 days. fast and good service!
