285s only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Jul 30, 2010.
  1. Jul 30, 2010 at 7:52 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Alright so here is the deal. I want to lift my truck and add 285s but I am a little skeptic after driving my brother's F150. He recently added a readylift and upgraded from 265s to 285s. Right away I could notice the loss in power when pressing the gas when stopped and the loss in braking power once I got to speed. My question is this: can the bigger tires actually cause damage due to the higher rpm required to roll or I am I over analyzing this. Is it really noticable or have you all just changed your driving style? Please post your opinion if you have 285s
  2. Jul 30, 2010 at 7:57 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    285's will be a heavier tire, more rotational mass... and it will affect the acceleration and braking. However I wouldn't suspect that much on our v6. I'm going 285's also... I'm more concerned with trimming and rubbing UCA's than performance loss with our v6. It's all about gearing... and it seems most people on here don't really need to think about re-gearing until they start hitting 35's and such.
  3. Jul 31, 2010 at 8:22 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    lower gas mileage... check
    quicker brake wear... check
    rubbing issues... check
    quicker CV boot wear... check
    hassles if you get a flat... check
    Looks killer and worth the trouble IMO.
  4. Jul 31, 2010 at 8:36 AM
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    ^^ x2 haha.. yeah acceleration from stop noticeably slower feels like your are towing something haha.. my 285s alone weights 58lbs each, plus wheels are like 22-24 lbs= 80lbs each wheel.. my stock 16s w/tires are like 62lbs. Once its starts to move though its no longer as bad
  5. Jul 31, 2010 at 8:40 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    My solution to the sluggish feel is a supercharger :p
  6. Jul 31, 2010 at 8:40 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    I can still break the tires loose on asphalt.
  7. Jul 31, 2010 at 8:46 AM
    Ace83
    TX
    SR5
    yeah it should still break loose of you really gun it..
    just curious have you done or tried this? coz im thinking you will still feel sluggish response on regular driving from a stop unless you put a good throttle each time and still doesnt help with mpg. Once rolling though, s/c should mskr you feel great again
  8. Jul 31, 2010 at 9:02 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    No my truck is still stock lol. It's on a very long list of upgrades I want to do though. I did put bigger (though 265) BFG AT's on my last... honestly it rode better and I could burn rubber all day no issue. They were fairly heavier than the rugged fails too.
  9. Jul 31, 2010 at 9:04 AM
    Ace83
    TX
    SR5
    im thinking of going forced induction too but prolly on next 2-3 yrs or so lol.. trd s/c might be the least hassle route
  10. Jul 31, 2010 at 9:12 AM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    your least hassle route is actually re-gearing. you can get some power and mpg back.
  11. Jul 31, 2010 at 9:14 AM
    Ace83
    TX
    SR5
    ^^ taking about forced induction (sorry off topic).. but regearing it is, yes
  12. Jul 31, 2010 at 9:20 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I'll probably do the TRD SC to maintain the warranty... unless I wait to long to do it then I'll probably save up for a URD Mark III setup. Even with the TRD though, you can add on most of the URD performance bits (such as underdrive pullies) and bump up way over the 300hp stock trd setup...
  13. Jul 31, 2010 at 9:22 AM
    Oskie_78
    Oskie_78 Everything's BIGGER in TX!
    Oscar
    Corpus Christi, TX
    2010 DC TRD Sport 4x4
    it's all worth it! imo
  14. Jul 31, 2010 at 9:28 AM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    As much as I hate to say this... aesthetically, its worth the trouble!
    I love my 295s!
  15. Jul 31, 2010 at 9:51 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    andrew, r those nittos?
    Don't be afraid to 285. I can light my 33's up like a christmas tree with the 6speed manual
  16. Jul 31, 2010 at 9:54 AM
    AriZonaD54
    Andrew
    Valley of the Sun
    Yes. Nitto Trail Grapplers 295/70/17
  17. Jul 31, 2010 at 9:57 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ridiculous... unless you are a 2.7l you'll hardly notice the difference between 265s and 285s... I've had both.
    Now I have 305/65/17s which are just about the same as 285/70/17s
    but it could be because I have a manual trans
  18. Jul 31, 2010 at 10:28 AM
    Ace83
    TX
    SR5
    ^^ oh yeah it could be the manual trans.. auto still not as smart as humans haha.. i wished i had a manual but damn hard to find on tacos lol.. i wonder how much more trimming will be done for 295 or 305 compared to 285
  19. Jul 31, 2010 at 10:36 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    How are you liking the Trail grapplers?
    I wish they weren't as soft as they are. But man do they bite :)
  20. Jul 31, 2010 at 11:23 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    no more power braking with the 285's. ive tried a few times and it will only rev a little and nothing will happen..haha
