285's or 265's???
Discussion in '1st Gen. Tacomas (1995-2004)' started by staplak, Dec 8, 2009.
  1. Dec 8, 2009 at 10:54 AM
    staplak
    staplak [OP] Well-Known Member
    Guntersville, AL
    04 Black Prerunner SR5 DoubleCab
    Thule Xsporter Rack
    I have just got my bilstein 5100's in today and 1.5" shackles for the back. I am debating putting on 265/75/16's or 285's on stock rims. I know that the 285's will have a little rubbing but they sure do look better from the pics i have seen. I have heard a lot of people say that you need new uca's or spacers. UCA's are a little out of my price range. I am just looking for some advice and opinions. Also if anyone has pics of trucks with the 265's and 285's with 2.5" lift please send them my way.
  2. Dec 8, 2009 at 11:12 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well you could run a 285, but yes it will rub and you will probably need wheel spacers If you dont get new wheels. But it will def. look way better then the 265's. :)
    I say go for the 285's! and do some trimming and then see if your ganna need spacers or not. :)
  3. Dec 8, 2009 at 11:14 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you dont need UCAs
    but at stock backspacing, aggressive 285-75 sidewalls may end up rubbin up against the stock UCA...
    to clear the UCA and the frame at full lock, you may want to stick to 4" backspace wheels or get 1/2" wheel spacers on the stock wheels...
    before i went LT, i ran 285-75s on 3" coilover lift...
  4. Dec 8, 2009 at 11:23 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Thank you. I like your rims. What are they? What size?
  5. Dec 8, 2009 at 11:25 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Anybody else with pics?
  6. Dec 8, 2009 at 11:31 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    285/70/17
    more pics in my gallery
    Also, like some have said, you will prob need wheel spacers with 285s and stock rims. IMO, I would get aftermarket rims with proper backspacing. If it's out of your budget, stick to 265s, less headache(s) on stock rims.
  7. Dec 8, 2009 at 12:02 PM
    ETaco23
    Evan
    PNW
    Thanks! there the Ulta 164's that Lesschwab carries. There 16x8 with a 4.25" Backspacing.
    I liked them too when I first got them, But when I get new tires I will be getting new wheels, most likely black.
  8. Dec 8, 2009 at 12:06 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    You should be in business then. If you get the new wheels then go for the 285s. I have 265s on 3'' of lift and I think it looks funky. Cant wait to get my 285s later this month!
  9. Dec 8, 2009 at 12:06 PM
    dylandercole
    Dylan
    o crap sorry. that wasnt the OP my bad. Im a dummy
  10. Dec 8, 2009 at 12:55 PM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    anymore pics?
  11. Dec 8, 2009 at 1:20 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    ya im running 285-70-17 on stock rims with my 3 inch lift, There is no rubbing except at full turn, then they hit the uca. My wheel spacers got here today to fix that tho.
  12. Dec 8, 2009 at 1:28 PM
    toyotadude5
    chris
    Flagstaff, az
    the pics didnt work. here they are.
  13. Dec 8, 2009 at 9:50 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Here's my '01 double cab on 285's. It's lifted 3" and the tires only rub on the frame near full lock. They will hit the UCA when the suspension tops out, but my buddies over at Spidertrax sent me some stuff today to take care of that.
  14. Dec 9, 2009 at 5:32 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Ok. I think i made my decision seeing your truck. That is sharp!
  15. Dec 9, 2009 at 5:32 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    They are dirty and these are 17" rims but you get the idea. Front is stock height and back is a 3" tough country AAL. The rims are from a chevy and I have no rub on the UCA's but I rub on the frame at full turn and I rub around the pinch weld when I hit bumps or go around a turn too fast.
  16. Dec 9, 2009 at 5:35 AM
    matthew5olson
    matthew
    pittsburgh, PA
    I like the 285's because of the tire width. Gives nice traction. I went from 245's to 285's so was a big jump for me. And by the way although my 285's are mounted on 17" rims the aspect ratio (belive thats what its called) is only 70 so 285/75R16 are the same size as mine
  17. Dec 9, 2009 at 5:37 AM
    kevhogaz
    SR5 PreRunner
    Thanks buddy! I'm putting the Spidertrax spacers on today, and hopefully that will cure my tire rubbing.
  18. Dec 9, 2009 at 6:03 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    If I order the spidertrax,(this may be a stupid question) do i need only two for the front or 4 for all 4 corners? And how is your gas mileage?
  19. Dec 9, 2009 at 6:39 AM
    kevhogaz
    SR5 PreRunner
    I'm only putting the spacers in the front. I have zero issues with the rear, so until I can afford a set of new wheels, only the front will get widened.
    As faras mileage goes, I was averaging about 17-19 with the 265's. I'm still on my first tank with the big tires, so I can't tell which way I'm gonna go as far as MPG.
    I mostly drive freeway, so if anything my mileage might go up a little, since I've knocked my gear ratio down a little bit.
  20. Dec 9, 2009 at 7:42 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Thanks for your help. If u dont mind let me know how the new wheel spacers turn out. I am curious to know.
