285s, stock wheels, LR UCAs... Wheel spacers needed?
Discussion in 'Wheels & Tires' started by Magnetic, Nov 12, 2009.
  1. Nov 12, 2009 at 7:20 PM
    Magnetic
    Magnetic [OP] Active Member
    Baton Rouge, La
    09 TRD-Off Road, locker mod
    Anyone running this combination? Are the LR UCAs enough to negate the need for Spidertrax?
  2. Nov 12, 2009 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They should give plenty of room for running without the spacers.
  3. Nov 12, 2009 at 8:11 PM
    dirtytoy
    dirtytoy New Member
    Dave
    SoCal
    '06 Tacoma TRD 4X4
    ICON Coilovers & UCA, Custom 10" Fox resis by Richer Racing & Deavers in back, Cust Demelo Sliders, Garmin Nav, Rock lights, Boxed frame, BFG 285 75 16R A/T, PowerTank, SnugTop shell
    Yap - you will need 1/4 spacers in front and even so they may still rub slightly at full lock in reverse. The stock wheels have 5.25 Back Spacing (BS) most manufacture (i.e. ICON) recommend max of 5.00 - while most aftermarket wheel land in the 4.5 BS range this often requires body mount mode. I have had 285 with stock wheels for 2 years its the best size to use without major mods - you will have to 4lb sledge the pinch welds in front.
  4. Nov 13, 2009 at 6:07 AM
    Magnetic
    Baton Rouge, La
    Thanks. I was thinking instead of dropping $200 on Spidertrax, put it toward the LR UCAs in the group buy and it would be better spent.
