285s with no rubbing?
Discussion in 'Wheels & Tires' started by BakerTaco, Jul 16, 2012.
  1. Jul 16, 2012 at 9:18 PM
    BakerTaco
    BakerTaco [OP] Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Is anybody running 285 All Terrains with stock UCAs and a 3in lift with no rubbing? A bit of plastic trimming is fine.
  2. Jul 17, 2012 at 4:25 PM
    bigswoleone
    bigswoleone Well-Known Member
    Craig
    Birmingham, AL
    11 DC PreRunner TRD Sport
    Alpine CDA-117 HU DLS Ultimate UP6i 6.5" comps Polk 6.5" coaxial rear-fill Polk MM series 10" sub Kicker ZX700.5 amp
    Maybe with aftermarket wheels or stock wheels with wheel spacers. Even then there would be at least some trimming of the plastic inside the fender.
  3. Jul 17, 2012 at 4:27 PM
    sdwiredog
    sdwiredog KTM Rider
    Phoenix, AZ
    Icons UCA's Deavers ARB rear locker Skids
    Try looking up the cab mount chop under the mods section. That's for '05 or newer.
  4. Jul 17, 2012 at 4:32 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    I was hoping that someone had a success story without the cab mount chop because its my dad's truck and he would notice if I did something that major.
  5. Jul 17, 2012 at 4:34 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I'm running 285's with 1.5" spacers. Nominal rub on the rear plastic of the fender well, and light rub at the steering stop, against the frame. I will be trimming the fender well plastic. I just put on LR UCA's but it was the same with the stock UCA's.
  6. Jul 17, 2012 at 4:36 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Why are you looking for the ONE guy who doesn't rub when 99.999999% of people do and require major modifications?
    If you want 285's just get them and do the mods. If your afraid of dad buy the right sized tires.
  7. Jul 17, 2012 at 4:38 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    1.5 inch wheel spacers?
  8. Jul 17, 2012 at 4:38 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  9. Jul 17, 2012 at 4:39 PM
    dpalmer619
    dpalmer619 Well-Known Member
    Derek
    San Diego
    '07 White TRD sport doublecab
    Icon 2.5 coilovers
    cab chop isnt that noticeable if your not looking for it
  10. Jul 17, 2012 at 4:42 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    i don't rub with 1.25" spacers and the arb bumper
  11. Jul 17, 2012 at 4:42 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Well the only success stories I've seen have been with BFG A/Ts just like taco47001. 99.999999% of people have big bulky mud tires and not all tire sizes are the exact same
  12. Jul 17, 2012 at 4:44 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    Ive got 285 duratracs on stock sport 17's and spidertrax 1.25 inch spacers, i just had to trim some plastic and i dont rub even at full lock and flexing
  13. Jul 17, 2012 at 4:52 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    285 duratracs on a 3" lift, had to trim the plastic right where it meets the bumper both sides. With that trim, no rubbing at full lock and flex.
    Oh yeah, aftermarket rims so no spacer
  14. Jul 17, 2012 at 4:55 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    So what's the deal with aftermarket rims and backspacing and such? What backspace numbers should you aim for? This stuff is like hieroglyphics to me
  15. Jul 17, 2012 at 5:07 PM
    jeremy1ns
    jeremy1ns Gamecock Tacos
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    None yet, but its about to get rolling.
    X2
  16. Jul 17, 2012 at 5:25 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Do you do any wheeling where your front tires get stuffed?
  17. Jul 17, 2012 at 5:28 PM
    XXXX
    sKiP
    05 Prius
    they can't be...
    I'm rubbing inside the frame and ripping off mud flaps with 265/70/17's so thats the inside and outside.
  18. Jul 17, 2012 at 5:34 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Swaa ?
    You change back ?
  19. Jul 17, 2012 at 5:43 PM
    XXXX
    sKiP
    05 Prius
    nope... I should of said "I was" - they are in my basement waiting for snow.. still got plenty of tread left
  20. Jul 17, 2012 at 6:12 PM
    DevL
    DevL Well-Known Member
    If you have the tools and time just do the cab mount chop with BAMF plates. I have had mechanics and bodymen look at my work... with zero experience I did the cab mount chop and made it look good with lots of grinding and sanding and filling in the swiss cheese of holes in the crappy welds with JB weld and fishied with Rustoleum flat black and they all say they would not have noticed it was not stock if I had not pointed it out.
    The BAMF plates make the mod a breeze. Its the grinding and sanding and JB Welding in flaws that took time. Also I was a pussy and afraid to cut so made more cuts than needed. Any welder will work for this mod and any shitty welds will work as long as you have some penentration and dont blow it out. All in all it took 5 hours. And you have as much experience as me in body work which was none.
    You also need to take a sledge hammer and knock over the pinch weld 9" high.
