285s; Would you do it again?
Discussion in 'Wheels & Tires' started by Tacoma13_NC, Dec 28, 2023.
If you had to do it again...
  1. 255/75/17
    9 vote(s)
    15.8%
  2. 265/70/17
    10 vote(s)
    17.5%
  3. 285/70/17
    33 vote(s)
    57.9%
  4. Function over Fashion
    5 vote(s)
    8.8%
  1. Mar 24, 2024 at 11:07 AM
    #41
    TacoTuesday1
    FL
    baja boss tall skinny 35
  2. Mar 24, 2024 at 11:10 AM
    #42
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Cool, I appreciate the info. I’m not sure what other tires you have run but would you describe the road noise as the same as an all terrain tire? Or closer to a mud tire? I’ve read as many reviews as I can find and some people call them quiet and others say they are pretty loud.
  3. Mar 24, 2024 at 11:14 AM
    #43
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    yes, 285-75-16's. 75,000 . On second set.
  4. Mar 24, 2024 at 11:15 AM
    #44
    Jasskillman
    Jasskillman Well-Known Member
    SoCal
    2013 DCSB
    I went with 255/75/17, dont have them mounted yet but seemed like the best/safest option to avoid any chopping/rubbing and E rated tires.. almost went with 285/70/17 because my dad was taking them off his jeep but didn’t want to gamble with rubbing and mpgs
  5. Mar 24, 2024 at 11:35 AM
    #45
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    Yeah mickeys in general seem to be a little louder than other brands. If a aggressive tire last a long time then the rubber has to be pretty hard which is more likely to be louder than a soft compound that wears out quickly.
    Road_Warrior[QUOTED] likes this.
  6. Mar 24, 2024 at 11:58 AM
    #46
    MBO
    MBO Well-Known Member
    Thought about 275/70r17? It’s a good in between size
  7. Mar 24, 2024 at 1:33 PM
    #47
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Good to know, thank you sir!!
    banditcamp[QUOTED] likes this.
  8. Mar 24, 2024 at 1:37 PM
    #48
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Yes 285/75/16
    jerrybear likes this.
  9. Mar 24, 2024 at 6:04 PM
    #49
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    X5 Absolutely would
    285/75/16
  10. Mar 25, 2024 at 11:28 AM
    #50
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I went with 275/70/17. Had to do some minor plastic trimming/cleared the cab mount by a 1/2". Trimmed the mudflaps and don't know if it was nessesary but did the pinch weld mod. Avoided a cmc, regear, and minimized power and mpg loss.
    Road_Warrior and Discount Tire like this.
  11. Mar 25, 2024 at 12:18 PM
    #51
    MBO
    Good call! I’m leaning towards the 275/70R17 also. What wheels did you go with? Can’t make it out from the pic.
  12. Mar 25, 2024 at 4:32 PM
    #52
    OffroadToy
    Method NV 305 Double Black 17x 8.5 4.75 bs/0 offset
  13. Mar 25, 2024 at 4:42 PM
    #53
    MBO
    cool! Did you have any rubbing with that size?
  14. Mar 26, 2024 at 10:22 AM
    #54
    OffroadToy
    Rubbed that black plastic part hanging down in front of tires and mud flaps. Ended up getting the mud flaps back on with some creative trimming in front of cab mounts.
  15. Mar 26, 2024 at 10:50 AM
    #55
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    think I have a load range C, 285/75 17 BFG KO2, got them though Discount tire. when did you get the tires?
    Discount Tire likes this.
  16. Mar 26, 2024 at 11:29 AM
    #56
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    You most likely have 285/70/17 if they are "C". BFG does not show 285/75/17 in anything other than "E". Shop All Terrain T/A KO2 Tires | BFGoodrich Tires I have had then a couple years but truck does not get driven a lot. Discount also shows 285/75/17 only in a 121S "E" load rating.
  17. Mar 27, 2024 at 7:00 AM
    #57
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    How do you like those RT Trails. This is one of the tires that I'm looking at next.
  18. Mar 27, 2024 at 8:15 AM
    #58
    BigCountry762x39
    TL
    PNW, Oregon!
    ill have to go double check now, but they are 285/75 17, requested a load range C tire, so if they are E rated would explain why the truck seems extra sluggish.
  19. Mar 27, 2024 at 8:18 AM
    #59
    OffroadToy
    Love the look... knew it was my next tire the minute i saw them. The road noise is hardly noticable... handling is great. Did good in snow in 4WD... little dicey in 2WD. Be sure to start slowing down early on ice coming down a hill to a stop.... they aren't winter snow rated so keep that in mind. Went up from bfg a/t E rated 265/75/16... no noticable loss of power even towing boat up to lake at 6,000'.
    Road_Warrior likes this.
  20. Mar 27, 2024 at 6:38 PM
    #60
    MBO
    Anyone have some Nitto ridge?
