285s......
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, Jun 3, 2009.
  1. Jun 3, 2009 at 9:23 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    ive had my 285s on for abt 2 weeks now and the loss of power is KILLING MEEEE. im a frequent interstate traveler for my job. i have a work truck but drive mine to the airport often. if you dont run 75 or 80 mph you get run over...i have the TRD s/c, jba headers and a exhaust...wtf do i do to get more out of my truck????
  2. Jun 3, 2009 at 9:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Gears.
  3. Jun 3, 2009 at 9:25 PM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    These things should do your car justice :D
    1. URD Y pipe
    2. URD Air intake
    3. URD MAF
    4. URD 7th fuel injector + bigger fuel bump
  4. Jun 3, 2009 at 9:28 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    i'm having the same problem. regearing is in my future
  5. Jun 3, 2009 at 9:29 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    regear??
    my local "shop" did a custom y pipe, i got the decplate mod, ill look into the MAF, and i got the 7th injector kit, and bigger fuel pump??? i also thought about a bigger throttle body??? do they make em?
  6. Jun 3, 2009 at 9:29 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got 285's with no S/C and I def. felt a loss in power, but I dont think its too bad, Im ganna be putting on some TRD headers to help.
  7. Jun 3, 2009 at 9:31 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    idk maybe its just my truck??? i pull a bass boat to the lake about every other day and its like it kills it at like 50 or 55 mph
  8. Jun 3, 2009 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gears will give the most performance increase for the dollar. If your a Prerunner, your looking at only $500.00 or so for new gears.
  9. Jun 3, 2009 at 9:41 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks for the info....what would i need to gear to?
  10. Jun 3, 2009 at 9:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive the Stock Gears uin your truck are 4:10's...Try and find some 4:56's. Keep in mind, your reves will increase about 400 +/- rpm in top gear on the freeway.
  11. Jun 3, 2009 at 10:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Hey my 02 prerunner had 3.90 gears, 4.56 is still a good gear to go with.
  12. Jun 3, 2009 at 10:24 PM
    ETaco23
    Evan
    PNW
    What type of performance will it give? some #'s if someone know's?
  13. Jun 3, 2009 at 10:25 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    itll bring your power back
  14. Jun 3, 2009 at 10:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. It doesnt give you "Power", rather it increases the leverage your engine has over the tires.
  15. Jun 4, 2009 at 12:12 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks guys
