285X70X16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eric2009Taco, Jul 11, 2019.
  1. Jul 11, 2019 at 12:56 AM
    Eric2009Taco
    Eric2009Taco [OP] Well-Known Member
    eric
    stock 2009 base Tacoma 4X4
    ARE camper shell, black wheels, and BF Goodrich tires
    will 285’s fit with a 2.75 lift? Thanks
  2. Jul 11, 2019 at 1:22 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    You’ll most likely need a cab mount chop to clear them.
  3. Jul 11, 2019 at 4:36 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    yes, no CMC needed. 285/70's are a tad smaller than the more common 285/75's that most here run,including myself. Wheels backspacing should be 4.5 or less and possibly some trimming of inner plastic of the wheel well if needed along with removal of front mudflaps.
  4. Jul 11, 2019 at 1:07 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Wheel offset and width will determine how and if they’ll fit.
  5. Jul 11, 2019 at 9:37 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Like he said wheel offset will play a large factor here. Either way you will probably rub the cab mount in certain situations... I actually would almost guarantee that you will rub the cab mount... but something you can definitely live with especially just daily driving. Having an alignment shop move the caster to where the wheels are more forward can help too. I have 255 85 16s with a cab mount chop and still rub at full lock when backing up or when stuffed. Good luck and don't forget to post pictures.
  6. Jul 11, 2019 at 10:42 PM
    steveo27
    Pittsburgh
    I have 285/75s and a hair under 3” of lift up front. Negative offset wheels. No cab mount chop
    The kicker is the alignment is set so the wheels are pushed as far foreword as physically possible. Instead of doing a cab mount chop I had to trim the shit outta the fender liners and bottoms of the flaresto make more room on the bumper side.
    I think you can run 285/70/16s with that lift and no CMC if you have adjustable UCAs and push you alignment as far forward as possible like I mentioned. And run the correct wheel offset and width.
  7. Jul 12, 2019 at 8:15 AM
    Eric2009Taco
    eric
    Thinking about going with 275X75X16....I have the Bilstein 5100, I'm getting on there & stock springs, up front & bought me some TRD (new) that where for a FJ. Not black, aluminum. 16X7.5, will have to see what that looks like.
