285x75R16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Dec 2, 2016.
  1. Dec 2, 2016 at 5:52 AM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    I have 2008 off road with Bilsteins at the 3rd height setting. Will 285x75R16 work? Didn't see an answer in search .
    Thanks
  2. Dec 2, 2016 at 5:59 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    That tire size generally needs 3" of lift and trimming AND a cab mount chop if you plan on flexing the suspension.
  3. Dec 2, 2016 at 6:01 AM
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
  4. Dec 2, 2016 at 6:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    You'll also need wheels with a backspacing of 4.5"
    DustStorm4x4 likes this.
  5. Dec 2, 2016 at 6:02 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    If you actually search there's a ton of threads about 285's. What it all comes down to to is your wheel backspacing, wheel offset, and how much your willing to cut/trim. Yes you can fit 285's but you will definitely rub on something without cutting/trimming. Some fendor trimming and a CMC at the least to run 285's with a little less worry. If you off-road at all you'll definitely still rub even with trimming and a CMC when you flex. Street wise you'd be fine.
  6. Dec 2, 2016 at 6:04 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Thanks, question answered.
