285x75x16 on stock rims
Discussion in 'Wheels & Tires' started by jeeezy, Jun 2, 2011.
  1. Jun 2, 2011 at 6:33 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    can it be done without wheel spacers or will it hit on the UCA?
  2. Jun 2, 2011 at 6:34 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Boone, NC
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    my understanding is it WILL hit
  3. Jun 2, 2011 at 6:34 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    dammit guess im stuck to go with 265's then
  4. Jun 2, 2011 at 6:35 AM
    TacoIII
    Andrew
    Boone, NC
    spacers are not that expensive 100 bucks and problem is solved
  5. Jun 2, 2011 at 6:38 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    hmm... even still if the 285's are the same width as the 265's then they should clear the uca's im not worried about them rubbing on the cab mount i can trim that back later on...
  6. Jun 2, 2011 at 6:41 AM
    TacoIII
    Andrew
    Boone, NC
    the 265 are shorter and the extra height of the 285 is what makes them hit. are you running a lift?
  7. Jun 2, 2011 at 6:42 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    yea but just the ready spacer lift
  8. Jun 2, 2011 at 6:44 AM
    TacoIII
    Andrew
    Boone, NC
    with 3 inches you should clear, if im wrong someone should chime in. you might scrub at full lock but spacers should make it bearable it your not a hardcore wheeler.
  9. Jun 2, 2011 at 8:00 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    i dont offroad very much and when i do its not very hard, im going to a shop today to get tires thrown on my stock rims so i was just curious on what to go with
  10. Jun 2, 2011 at 8:15 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm kinda in the same boat here except not worried about rubbage. New to me 08 prerunner has no lift and I won't be doing any more than 1/2" up front this time using 1/4" toytec taco lean top plate spacers on both sides with the TRD Bilsteins going in up front in place of the tokicos. I have 245/75/16s now but in 35k or so when they wear out, I was thinking of doing 1.25 wheel spacers and going with 285/65/16 or closest 285 OD size to the others but thinking about just bumping up to 265/70/16s and skipping the wheel spacers.
  11. Jun 2, 2011 at 5:43 PM
    michaelg589
    michaelg589 Well-Known Member
    285s are wider than a 265... hence the 285. :rolleyes:
  12. Jun 3, 2011 at 8:31 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    went with the 265's :p
