29 MPG on a 2022 Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shocked, Nov 28, 2021.
  1. Sep 27, 2023 at 5:41 AM
    #81
    Fishersehorn31
    Fishersehorn31 Active Member
    Speaking of fuel economy... assume cruising on flat ground in a MT:
    - Is it more economical to be in 6th gear at 50mph or a lower gear?
    -Lower RPMs the better?
    Essentially, how to maximize fuel economy with a manual transmission.
  2. Sep 27, 2023 at 6:39 AM
    #82
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    Just fucking drive it
    2wdSR52022 and 0314TrailEdition like this.
  3. Sep 27, 2023 at 6:42 AM
    #83
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    255/85R16's, overinflated, driving at 60mph in top gear in a 6mt, cruise control on flat ground, I could manage 23-25. Add a little down slope and 30 would be easy.
    29 around town is damned near impossible unless he's testing some secret squirrel hybrid.
  4. Sep 27, 2023 at 12:39 PM
    #84
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    You must have just filled up
  5. Sep 27, 2023 at 1:34 PM
    #85
    Bluridge120
    Bluridge120 Well-Known Member
    EM85
    22 TRDOR DCSB AT CSM
    If u have a scooop you'll get 12. If not, 27. It's pretty simple.
  6. Sep 27, 2023 at 1:40 PM
    #86
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    It's weird but you save more gas coasting down in drive as long as the transmission is keeping the engine over some 1500 rpm fuel is shut off, at idle you still need some fuel.
    LOL dang I fell for another 2 year old thread =)
  7. Sep 27, 2023 at 2:15 PM
    #87
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I use trip meter A for overall mileage until next fuel up.
    Trip meter B is for overall single trek...like this weekend we went from Dover, DE to Glenn Mills, PA...over all 120+ miles for the day. (1/4 gas used)
    Back to the overall mileage between fill ups...I get close to 400 miles per tankful (400 miles/22 tank size = 18.1818)
    I use unleaded 87 octane gas and can sometimes drive like a grandad.
    I'm ok with the average mileage I get...it was similar to the 2003 Honda Pilot I had that also had a V6/3.5 but a 19 gallon tank.
  8. Sep 28, 2023 at 7:04 AM
    #88
    tarbal255
    Dave
    19 Taco SR
    Fuelly indicates otherwise. My 2.7 used to get me around 21-22mpg with a 50/50 mix city/highway but lately it's 0.9 mile stints to nowhere so I'm getting 19 as the 2.7 is cold blooded and needs to warm up. Long trips I'm always around 23-24 at 70mph. If you use the Fuelly numbers it's about 2 mpg more which isn't much but it does mean I get around 400+ miles out of a tank of gas.
  9. Sep 28, 2023 at 5:16 PM
    #89
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    One thing Fuelly doesn't do a great job at doing is showcasing the types of uses these readings are for. For example: the 4-cylinder is rated better in the city and worse on the highway than the V6. I suspect those with the 4-cylinder are also using theirs less on the highway at 70+ mph.
  10. Sep 29, 2023 at 4:55 AM
    #90
    bluj62
    bluj62 Member
    john
    2018 SR5 Access Cab V6 4X4
    RedWings44 likes this.
  11. Sep 29, 2023 at 4:56 AM
    #91
    bluj62
    bluj62 Member
    john
    Still trying to navigate how to post photos. I'm kinda new to this sort of thing. Anyhow, above was driving down I-75 in Ohio. Pretty flat doing between 65-70
  12. Sep 29, 2023 at 4:58 AM
    #92
    bluj62
    bluj62 Member
    john
  13. Sep 29, 2023 at 4:58 AM
    #93
    bluj62
    bluj62 Member
    john
    Hwy with some city. Note the fuel gage. Driving in Cincinnati on a hot day.
  14. Sep 29, 2023 at 5:40 AM
    #94
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Pretty impressive @bluj62
    Any special operating conditions such as no AC on or were you drafting behind a 53' trailer!
  15. Sep 29, 2023 at 7:54 AM
    #95
    tarbal255
    Dave
    19 Taco SR
    How do I make sure to buy your V6 Taco??? I swear when I was researching most guys on tacomaworld were complaining about high teens on mpg. but a few guys like you somehow get a unicorn that does 30mpg which I can't get out of the 2.7. High 20s is best I can do at 60-65 on the highway which is darn slow.
    I think next time I need to test drive several of the same car, drive them all down the highway at 75mph and record mpg then choose the ringer.
    With your engine/driving skill you must easily get 400+ miles out of a full tank of gas don't you?
  16. Sep 29, 2023 at 9:41 AM
    #96
    MonkeyChief
    ACORLR
    I solved my MPG woes by turning that screen off on the dash so it’s blank when I’m driving. When I turn off the truck and it flashes trip MPG, I look away, problem solved!
    I also don’t look at how much each tank costs, because that’s how much each tank costs. I look at the aggregate from time to time, but not too often as it’s pretty consistent and within my overall expectations.
    I’ve always understood that it’s functionality that drives the Tacoma, not MPGs, none of my Toyota trucks have even gotten good gas mileage so I guess my expectations are low.
  17. Sep 29, 2023 at 10:02 AM
    #97
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    nice but be careful with 40psi in the tires
