295/70/17? Did some minor trimming still rubbing
Discussion in 'Wheels & Tires' started by Atron22, Aug 24, 2010.
  1. Aug 24, 2010 at 3:27 PM
    Atron22
    Atron22 [OP] Well-Known Member
    San Felipe Peublo, New Mexico
    05 Taco Double Cab 4x4
    K&N Cold Air intake 77 Series, 3 inch leveling kit front, AAL w 1 1/2 inch block, rear Pro Comp ES9000 Shocks, Dynomax Catback Exhuast.
    I am running a 295/70/17 on my 05 taco DC. I did some trimming and still rubbing. Any ideas guys? Would spacer help me? :confused:
  2. Aug 24, 2010 at 5:45 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    1. which wheel?
    2. spacers work (spidertraxx)
  3. Aug 24, 2010 at 6:07 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    You might need just a mini 1 inch spacer. Or even a set of spydertrax. When I go to the 70 series tires I hope I have money for 5100.
  4. Aug 24, 2010 at 6:09 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Have you chopped your cab mounts? What exactly are you rubbing on?
  5. Aug 24, 2010 at 6:10 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ok the only reason you should need spacers if you are rubbing on the upper control arm, where are you rubbing it will help us narrow this down.
  6. Aug 24, 2010 at 6:16 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    This and then chop the living daylights out of the inner fender trim.
  7. Aug 24, 2010 at 6:18 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Haha, mine is just ripped out completely.
  8. Aug 24, 2010 at 6:19 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    My man! Da shit!
  9. Aug 24, 2010 at 6:20 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Soooo, e39? When is it going in? Or where you kidding?
  10. Aug 25, 2010 at 2:23 AM
    SpaceGoat
    SpaceGoat Active Member
    Hawaii
    07DoubleCabSR5
    Bilstien5100s all around, 1 inch blocks rear, Total Chaos UCAs, Body Cab mounts, Pioneer Head unit, 8 inch sub, Wet Okoles
    I'm running 285/70/17 ProComp xTremes and rubbed on the cab mounts, but just a quick trim and box in...all good. Have wheel lock to wheel lock...with almost no inner fenders :D but im only running 5100s at 2.5 up front, nothing else.
  11. Aug 25, 2010 at 7:03 AM
    Atron22
    I am rubbing on the inner fender, on metal, I guess that would be the cab mount. How would I go about trimming that?
  12. Aug 25, 2010 at 7:06 AM
    Atron22
    Where are the cab mounts located? :confused: Is this hard to do? What do I need as far as tools?
  13. Aug 26, 2010 at 3:57 AM
    SpaceGoat
    Hawaii
    07DoubleCabSR5
    Cab mounts are located closest to your cab...if you are looking at the drivers side front wheel, on your right. As for tools, saw's all i've been told it can be done but I took mine to my favorite 4x4 shop. He used plasma cutter then welded up a plate to "box" in the hole that was cut out, then painted over it all with undercoating. all for 100 bucks. YMMV.
