295/75/16 on TRD wheels?
Discussion in 'Wheels & Tires' started by sfcadams, Jan 26, 2012.
  1. Jan 26, 2012 at 9:56 PM
    sfcadams
    sfcadams [OP] Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I have tried searching for the answer but haven't found anything definitive.
    I have a 2011 DCSB TRD prerunner. I have the bilsteins at .85 with Eibach springs and the top plate spacer from Toytec for a total of 3 inches of lift in the front. I "believe" the backspacing on the factory TRD wheels are 5.25 inches. I am currently running the 1.25 inch Spidertrax to push the wheels out for a better look/stance with the factory 265/70/16s. I am thinking about moving up to a set of 295/75/16s and wanted to get some opinions on how others think this combo would work. I don't offroad, just mainly highway and the occasional light trail or something along those lines. Any help is appreciated!
    Thanks!
    :oldglory:
  2. Jan 27, 2012 at 5:12 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    bump....
  3. Jan 27, 2012 at 5:14 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    moved to wheels&tires for answer
  4. Jan 27, 2012 at 5:52 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There are folks running that size on a 3" lift. It just requires more trimming than the 285/75's.
  5. Jan 27, 2012 at 5:54 AM
    jhodge83
    SC
    might wanna check the tire manufacturer's specs on what they recommend for rim width. the stock 7" wheel might be too narrow for the 295. tires of the same size can have different recommendations from the manufacturer based off their testing.
  6. Jan 27, 2012 at 6:47 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    Thanks for putting this in the right forum.
    On a side note, I thought the stock TRD wheels were 16x8??
  7. Jan 27, 2012 at 6:48 AM
    jhodge83
    SC
    stock steelies and stock OR rims are 16x7 and stock Sport rims are 17x7.5, IIRC.
  8. Jan 27, 2012 at 6:51 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    It should work
  9. Jan 27, 2012 at 7:02 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    From the searches I am doing through Google, I keep reading that the stock TRD Off Road wheels are 16x8. Guess I am gonna have to pull a wheel off to see if the size might be stamped into the back of the wheel.....
  10. Jan 27, 2012 at 7:04 AM
    KPT
    09 Prerunner
    They are definitely 16x7.
  11. Jan 27, 2012 at 7:05 AM
    jhodge83
    SC
    it will be cast on the back of the wheel. only stock TRD wheels i know of that are 16x8 are the TX fake beadlocks.
  12. Feb 2, 2012 at 11:05 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    OP did you ever get 295s put on?
