295/75/16 questions
Discussion in 'Wheels & Tires' started by tacosupreme54, Oct 30, 2010.
  1. Oct 30, 2010 at 10:18 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i was just wondering if many people on here has 295's, if so, i have a few questions. i will be getting new tires sometime and have been really going back and forth between the 285's and 305's. but here recently i noticed the 295 and it seems like a good size. the 305's are basically a true 33x12.5, so that's a little too wide. the 285's are like 32.8x 11.25 and that's not much bigger than a 265/75. but the 295's actually range from 33.4 to around 34 and about 11.6 wide. one reason i want to lean away from the 305's or true 33s is because i don't want to chop the cab mount. but these 295's are an inch more narrow and a tad taller, so would that eliminate my rubbing there? also, i know some guys on here even chop the cab mount with 285's. but is that for more serious off roading to allow for flexing or is it for any use? because this truck is going to stay on pavement a pretty good bit until it's paid off. used strictly on the road, will these be an issue with the cab mounts? also, i have 2.5 in the front and 2 in the rear, plus 4.5 backspacing wheels. i realize that i will i have to cut out some plastic in the fenders and that's fine, i just don't want to get into anything more intense than that, lol.
    also anybody that considered or has 295's, why did you or did you not get them? are there any pros or cons with these compared to 285s and 305s? if its more trouble than it's worth to make these work, please let me know. if this is no trouble to make work without getting into the cab mount, please let me know. also, this is somewhat of an odd size and there are few brands to chose from. does anyone know a brand that makes this size to suggest? the only ones i've seen are hankook, general grabber, bf goodrich, and a couple others. i want more of an at or mt aggressive tire. i know it's asking a lot, but there is not much info on this size tire, nor many people that have them. so anybody with these or info on these, please help me out because i don't want to try to do things on my own and get myself in a mess.
    thanks guys
  2. Oct 30, 2010 at 10:20 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    stroM- has 295/75/16's and had to chop his cab mount.
  3. Oct 30, 2010 at 10:23 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    do you know if he did that to allow for some serious off roading? or if it's gonna have to be done no matter what?
  4. Oct 30, 2010 at 10:26 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    He had a lot of rubbing while turning in reverse. It was also done to allow for more clearance offroading and he has an aftermarket front bumper so I'm not sure how much cutting or trimming you will have to do in front of the tire.
  5. Oct 31, 2010 at 6:29 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    alright, thanks man. i'll just try to get in touch with him.
  6. Oct 31, 2010 at 6:32 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I think i have a idea what constitutes getting the cab chop, with stock UCAs I never rubbed the cab mount, but when I got UCAs and the right specs, I can no longer make U turns. I have 285s BTW
  7. Oct 31, 2010 at 6:36 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    so the new ucas and larger tires limited how far you can turn?
  8. Oct 31, 2010 at 6:37 PM
    ktmrider
    Junk
    not it just is eating my tire on the cab mount cause my caster is too low on the left side
  9. Oct 31, 2010 at 6:39 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    oh, ok. so at about how far of a turn does it start to rub bad? less than a full 90 degree turn?
  10. Oct 31, 2010 at 6:40 PM
    ktmrider
    Junk
    if you are going straight 1 and 3/4 turns to the left.
  11. Oct 31, 2010 at 6:48 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    oh, alright. thanks
  12. Oct 31, 2010 at 7:09 PM
    ktmrider
    Junk
    thats with a good 10k on the tires too, it would be worse if they were brand new
  13. Oct 31, 2010 at 8:23 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, i'm looking at hankook dynapro mt's. the actuall size of the 285/75/16 is 33x11.6 and the 295/75/16 is 33.6x 11.6. so is .6 of an inch going to make a ton of difference?
  14. Jun 28, 2011 at 8:14 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    Well I finally got around to getting these and having them put on. I had to drive a little careful on the way home to not rip my fenders and bumper off. But I got home, checked everything and cut back a few hunks of plastic on the inner rear fender and on the front fender/bumper. I had no trouble with the cab mount. I am clear lock to lock; even with the tires at the angle closest to the cab mount I have about 3/8-1/2'' clearance. I even tested my trimming on a small trail and had no rubbing. So as of now, no cab mount chop needed on my 295/75/16's (33.6'' x 11.6'').
    (yes, repost from another thread i had, but just passing on info for anyone that may reference this thread)
  15. Jun 28, 2011 at 8:16 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I would talk to Blacktacoma23 hes got em
  16. Jun 28, 2011 at 8:19 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    lol, I just posted to show that I had got them put on today and didn't need a cab mount chop
  17. Jun 28, 2011 at 8:21 PM
    BlueTaco07
    Cody
    Looking
    Ohh didnt see that. What size lift are you running?
  18. Jun 28, 2011 at 8:25 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    3" OME
  19. Jun 28, 2011 at 8:27 PM
    BlueTaco07
    Cody
    Looking
    You think once I get my procomp 3, I could clear the same size tire?
  20. Jun 28, 2011 at 8:31 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    u will if u wheel it hard
