295/75r16 & 295/70r17 PHOTO THREAD.
Discussion in 'Wheels & Tires' started by TrailYeti, Jan 26, 2019.
  1. Dec 30, 2019 at 12:37 PM
    #441
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    :bananadance:
  2. Dec 30, 2019 at 12:37 PM
    #442
    fatfurious2
    David
    Ashburn, VA
  3. Dec 30, 2019 at 12:38 PM
    #443
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    This site is a gateway drug lol
  4. Dec 30, 2019 at 1:14 PM
    #444
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    My truck with 295 70 r17 Nitto Terra Grapplers on 17x9 -12 wheels (1.25" Spidertrax in the front also). I love the tire size it does awesome for a semi-daily driver, hunting rig, and dirtbike hauler... but I kinda wish visually I went a tad bigger when I bumped the lift up but i definitely dig the practicality for my use
    TrailYeti[OP], RangerComa and irayfz6 like this.
  5. Dec 30, 2019 at 4:09 PM
    #445
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I used to, Ive posted earlier in this thread. I’ve since went 35s.
  6. Dec 31, 2019 at 12:08 PM
    #446
    Helpme
    Helpme Well-Known Member
    Orange County, CA
    2015 Tacoma DCSB
    Have been lurking this thread for a while.
    Just installed 295/75/16s :bananadance:
    293EF6BC-E0EA-4640-87AB-50CA4DA3CC0B.jpg 8F965123-C997-4FE0-BAFC-B2B2E231E4A7.jpg D8443BC3-3BE1-4A17-8831-B92AD400C1E6.jpg
  7. Dec 31, 2019 at 6:23 PM
    #447
    TrailYeti
    TrailYeti [OP] Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    I’ll still be around!
    Johnny DemonT and irayfz6 like this.
  8. Jan 1, 2020 at 9:59 PM
    #448
    Carter
    Carter Well-Known Member
    Carter
    Calgary AB
    14' Tacoma TRD Sport
    Toyotec Boss 3", Ridged Industries grill/light bar combo, TRD exhaust, Fender flares, 16" wheels with 33" Duratracs, Parrot Android Smart Deck, Custom Black Leather with red stitching.
    That's what I'm running and you'll likely need to chop. I havent yet, but I haven't taken it far enough off road for it to rub enough to bother me.
  9. Jan 2, 2020 at 6:44 PM
    #449
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Dang. I contemplated on going 295. Pretty sweet rides in here!
    Island Cruiser likes this.
  10. Jan 4, 2020 at 5:52 AM
    #450
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    What is your guess how a 17x9 285/70/17 would fit up in that stock location when doing your trim mod? Thanks!
  11. Jan 6, 2020 at 12:15 PM
    #451
    TrailYeti
    Portland, Oregon
  12. Jan 6, 2020 at 7:17 PM
    #452
    Tacoma_Runner1129
    Tacoma_Runner1129 Well-Known Member
    Arizona
    2018 DCSB TRD Sport 4x4 (Sold)
    What's your suspension setup? Did you have to hammer your pinchwelds to get the 295's to fit with the 16x8 Ray 10's? I have the same wheels and am looking at going to 295 once I have to replace my tires.
  13. Jan 6, 2020 at 7:45 PM
    #453
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I’m on fox dsc ext travel 650# coils, and SPC LR UCA’s. Caster should be at 3 degrees, with the lower cams maxed out forward and the rest dialed in at the adjustable ball joint on the UCA. I think I’m around 2” lift. Maybe 1.5 or 1.75”. I don’t know. Too lazy to keep measuring, I just know I’m in the sweet spot travel wise And my CV angles are good.
    As for the pinch weld, well, I pounded that bish flat a month or so before I got the new tires. It was really easy actually. Like really easy. I was all worried it would be a PITA, but was pleasantly surprised at how fast and easy it folded over. Did the cab mount a long time ago too.
    anyways, so I have no idea if it’s actually needed, but it’s an easy mod that takes about 5 mins per side of pounding/massaging. an hour total to jack the truck up, take off the wheels, remove the plastic liner clips and bend the plastic out the way, pound, paint, replace the clips and heat that plastic liner flat, put tires back on and roll away.
    From there it’s light plastic trimming at the bottom of the wheel well at the back where the mud flaps used to be. Nothing major.
    go for it. I like these tires and this set up.
  14. Jan 6, 2020 at 7:51 PM
    #454
    Tacoma_Runner1129
    Arizona
    Awesome, thanks for the detailed info! Sounds like this will be my future setup.
  15. Jan 14, 2020 at 7:55 PM
    #455
    TrailYeti
    Portland, Oregon
    Test fit a 35 today. :anonymous:
  16. Jan 14, 2020 at 8:00 PM
    #456
    Johnny DemonT
    SW Burbs of Chicago
    15 Silver DCLB
    Did you run them on the road at all?? Looks amazing!
    TrailYeti[QUOTED][OP] likes this.
  17. Jan 14, 2020 at 8:06 PM
    #457
    07taco
    07taco Well-Known Member
    san antonio
    2017 taco trd dclb
  18. Jan 15, 2020 at 6:28 AM
    #458
    TrailYeti
    Portland, Oregon
    Not yet. Just checked clearances lock to lock. I only have one 35 right now. Need to do more prep on the fenders/firewall before I buy 4 more and mount them.
    Johnny DemonT[QUOTED] likes this.
  19. Jan 17, 2020 at 11:07 PM
    #459
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    That is absolutely beautiful! Makes me want to order some now.
  20. Jan 17, 2020 at 11:35 PM
    #460
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    I had a shop give me 5+ degrees and I've been rolling around with it for the past few months. What kinds of issues should I be looking out for?
    TrailYeti[OP] likes this.
