295/75r16 & 295/70r17 PHOTO THREAD.
Discussion in 'Wheels & Tires' started by TrailYeti, Jan 26, 2019.
  1. Jul 14, 2022 at 9:21 PM
    #921
    Pengowirr
    Pengowirr Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    I been eyeing the Xlts on this size but it’s kinda of disappointing knowing they’re barely wider than a 265RG.
    i have the 265 ST Maxxes so if I upgraded all I would get is a taller tire?
    havw you measured the Xlts width?
  2. Jul 17, 2022 at 8:51 AM
    #922
    Jseda845
    Jseda845 Well-Known Member
    845 NY
    2019 TRD OR
    Dobinson's MRR coils, Deaver Stage 3 leafs, 295/70/17 Yokohama Geolander MT, ATHFab front & rear bumpers, DRT CMR, WarFab sliders, Archive Garage U-Bolt flip kit, SPC UCA (soon to be swapped)
  3. Jul 20, 2022 at 10:35 PM
    #923
    aka_ricerocket
    aka_ricerocket New Member
    Jimmy
    2022 Tacoma TRD offroad
    Everything under the Sun
    I can finally post here after Lurking for months while my Factory Order truck arrived.
    here it is on 295/70/17 KM3, wheels are Weds Hase Spec2 17x8.5 -6 offset 80AB5F90-3F73-4871-9C20-C3075957883F.jpg B648882B-FACC-4F1D-AD53-66CCBF200F83.jpg
    Raku77, Mully, MGMDesertTaco and 5 others like this.
  4. Jul 23, 2022 at 2:02 PM
    #924
    Pengowirr
    Looks amazing. The KM3s are so sexy
  5. Jul 31, 2022 at 10:00 AM
    #925
    Vol4
    Vol4 Well-Known Member
    What kind of hood deflector?? Looks sweet
  6. Jul 31, 2022 at 4:19 PM
    #926
    Beefchief
    Beefchief Well-Known Member
    San Diego
    2013 double cab trd off road 4x4
    not the best photos but just slapped 295/70r17 km3s on some rrw 17x8.5-12. Had to do a little more cutting to clear coming from 285s but they look much beefier. Especially with the -12 offset
    14DAF95F-5A4C-4297-AA9C-59D48A16494A.jpg 0F48EF53-CF44-4F7B-98B1-2AB9CCC4D96C.jpg
  7. Aug 1, 2022 at 2:17 AM
    #927
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
  8. Aug 10, 2022 at 6:17 AM
    #928
    RCTuningFL
    RCTuningFL OTT Tuner - Florida/Puerto Rico/Caribbean
    RC
    Melbourne, FL & Luquillo, Puerto Rico
    2020 Tacoma TRD Pro @rctuningflgarage
    OTT + Magnuson Supercharger w/ 80mm - 5.29s etc etc.
    Looks great on MGM. I'm about to do the same setup on Micky MTs. I'm hoping I I wont rub much... we will see.
  9. Aug 10, 2022 at 6:19 AM
    #929
    RCTuningFL
    RC
    3rd Genners running a 295 70 17.... how does the spare fit? I run a 285 75 16 which fits as my spare but going to a 295 70 17.
  10. Aug 10, 2022 at 6:44 AM
    #930
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    I've tried getting a spare to fit in stock location. I flattened the tabs but still cannot clear the shackle hangers. If you take air out you might be able to squeeze it in there. You may also need to have axle dump exhaust. I know it's not ideal but I just carry in bed until I can find a better solution
    RCTuningFL[QUOTED] likes this.
  11. Aug 10, 2022 at 6:47 AM
    #931
    RCTuningFL
    RC
    Thats what I plan on doing I guess. I didn't like how my spare on the 285 sagged down. Would have to remove for clearance when I hit the dirt anyways.
  12. Aug 10, 2022 at 7:54 AM
    #932
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Excellent choice!
    Do you guys accept 4Runner pics?
    Yokohama Geolander MT, 295/70/17.
  13. Aug 10, 2022 at 10:10 AM
    #933
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Can you please tell me much does the tires measure mounted and with the weight of the truck? I have the same wheel dimensions.
    I’m torn between 285/75 and 295/70
  14. Aug 10, 2022 at 3:26 PM
    #934
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    It would be tight and really hang down.
    I run a Cooper St Maxx 255/85/16 on the steel spare wheel. That's a tall skinny, 32.8" high and 10.2" wide. I run 295/70/17 Ridge Grapplers, which are 33.31" high and 11.77" wide. Close enough in a pinch.
    I had to drill 2 new holes for the hanger enabling it to move back about an inch, reusing the other 2 original holes. Even then, I use a ratchet strap to pull it all the way back against the hitch since I could see that it did still rub the pumpkin. Tabs flattened, exhaust chopped at the axle since it did rest on the heat shield
    Not sure any of that helps, but that's how I ended up doing it to run a full size spare
    chuymoreno likes this.
  15. Aug 10, 2022 at 8:59 PM
    #935
    SATXTACO
    SATXTACO Member
    2021 Tacoma TRD 4X4
    I’m looking at getting the TRD lift. 2in rear and 1in front, will Cooper 295/70/17 on a -20 offset work without any cutting or cmc?
  16. Aug 10, 2022 at 11:54 PM
    #936
    BRFab
    BC
    Longtech likes this.
  17. Aug 12, 2022 at 8:01 PM
    #937
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    Do you have a pic straight on the front or back to see the poke? I’m deciding between the -12 or -25
    Thank you!
  18. Aug 16, 2022 at 1:11 AM
    #938
    RCTuningFL
    RC
    295 70 17s!
    Mrod18, nglescobar1992, Mully and 5 others like this.
  19. Aug 16, 2022 at 12:54 PM
    #939
    Smk8609
    Smk8609 Well-Known Member
    2016 dcsb trd sport 4x4
    What lift/offset are you running there? About to refresh the suspension/tires and I just cant see 295/17 fitting on my current 2.5" setup
  20. Aug 16, 2022 at 1:20 PM
    #940
    RCTuningFL
    RC
    Wescott Pro Kit... maybe 2.5 inch? Icon Progressive AALs with overload left in. 17x8.5 RRWs. -12. 295 70 17s MTs. I rub on my flaps. I think if I removed I would be ok. I'm installing some UCAs soon to see if I can manipulate the rub with a good alignment.
