295 on a 2nd gen with 3" lift, can it be done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RBoyd0325, Feb 15, 2012.
  1. Feb 15, 2012 at 8:41 AM
    RBoyd0325
    RBoyd0325 [OP] Well-Known Member
    Richard
    Alabama
    08 TRD Off Road 4x4 3" lift
    Im trying to fit some 295/65/r18 goodyear duratracs on my taco but not sure if it can be done without hitting the ucas too bad of if its even possible. i dont mind trimming a little bit to help them clear. whats yalls thoughts?
  2. Feb 15, 2012 at 8:46 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    well 275's rub a little... Im sure it will fit, but it will rub pretty bad unless you stick to the mall.
  3. Feb 15, 2012 at 8:48 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    ROFL
  4. Feb 15, 2012 at 9:13 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    you will need aftermarket wheels or wheel spacers and alot of triming, including the Cab Mount chop.. which is really easy to do.
    It is doable, just takes a bit of triming...
  5. Feb 15, 2012 at 9:29 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I'm running 275/65/r16 duratracs on stock wheels with no issues
  6. Feb 15, 2012 at 11:00 AM
    RBoyd0325
    Richard
    Alabama
    Thanks guys. Yeah I think I'm going to go with the fuel kranks 18" with the 295 duratracs. I read blacktacoma23's build page and he's running 295s with 17" kmcs. He didn't have to do a body mount chop but he did have to do a lot of trimming inside the fender well. I'll also probably remove my sway bars and put in a high clearance skid plate
  7. Feb 15, 2012 at 11:03 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    be prepared to do a lot of cutting.
    go wheel and see where you need to cut
    then wheel again and cut some more....
  8. Feb 15, 2012 at 11:09 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I can fit a 315 you can fit a 295.
  9. Feb 15, 2012 at 11:10 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Nice find ;)
    X2
  10. Feb 15, 2012 at 11:12 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    im running 305-70-16's
    only thing that rubs is the cab mount. (i did cut the bottom of the fender flare to make em work.)
    eagle alloy rims...(backspacing does wonders)
  11. Feb 15, 2012 at 11:14 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    295/70/17 on stock sport wheels with 1.25'' spacers. had to chop and re-box the cab mount as you would with 285s, but did have to tim more off of the fender than normal. if you're going to be operating the truck throughout the suspension's range of motion, lift height doesn't have a thing to do with clearance. at full compression, if doesn't matter if you have 3 inches of lift or are at stock height. with the same wheel setup, you'll have the same clearance issues.
  12. Feb 15, 2012 at 10:01 PM
    RBoyd0325
    Richard
    Alabama
    thanks for your help guys, i think ill prolly just end up going 285/75/r17. less trimming and its cheaper!
