29er doesn't fit in DCSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rageman, Nov 26, 2019.
  1. Nov 26, 2019 at 4:58 AM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    I wonder if you could come up with a rig that lifts the attachment point for the fork higher thus bringing the rear end in? ‍
    Malvolio and InfernoChalupa like this.
  2. Nov 26, 2019 at 5:05 AM
    yotahunter
    yotahunter Well-Known Member
    Central Iowa
    2020 TRD Pro
    I have the same issue with my Fatboy. I put the fork mount on a board and put the bike in backwards.
  3. Nov 26, 2019 at 5:09 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Along this same line of thought - how about lifting the rear tire up and set it on something like a cooler?
  4. Nov 26, 2019 at 5:10 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
  5. Nov 26, 2019 at 5:14 AM
    Mattynokes
    Madison, WI
    Boo!
    BSFord likes this.
  6. Nov 26, 2019 at 5:16 AM
    Mattynokes
    Madison, WI
  7. Nov 26, 2019 at 5:19 AM
    aStrauss
    aStrauss Well-Known Member
    Andrew
    2019 TRD OR DCSB 6MT
    I have the same issue with mine. I have a Thule T2 also, which I’ll use if I need the bed space or if I’m riding with someone who I don’t have a thru-axle adapter for. The T2 Pro will not allow you to drop the tailgate without making contact with the rack, but the T2 classic clears by 1/8 to 1/4”
  8. Nov 26, 2019 at 5:23 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
  9. Nov 26, 2019 at 5:24 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Ran into the same issue with my 27.5 so had to go the tailgate pad route.
  10. Nov 26, 2019 at 5:26 AM
    HMM
    HMM Well-Known Member
    2020 TRD Pro
    Does anyone make an L bracket that puts the mounting point on top of the bed by the cab? That would give you an inch or two, not sure if that's enough but just a thought...
    InfernoChalupa likes this.
  11. Nov 26, 2019 at 5:27 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    But every time without the bike you look goofy. :infantry:
  12. Nov 26, 2019 at 5:28 AM
    Mattynokes
    Madison, WI
    :rofl:
    Malvolio likes this.
  13. Nov 26, 2019 at 5:30 AM
    aStrauss
    Andrew
    I thought about it with mine, but decided it was a terrible idea for one reason. I have QR fork mounts and need to run a thru-axle adapter for my 15mm T/A on my Habit, and a lefty adapter for my gravel slayer. The adapters have some free movement until the fork is tightened down, and even then, they can be forced to pivot. Closing the tailgate against the rear tire of my habit, so that it fits tight, will pivot my T/A adapter forward until it hits the bed rail. If it were mounted on the top of the bed rail, I’d worry about sending it right through the back window.
    If you run a T/A compatible fork mount like the one from RockyMounts, it shouldn’t be an issue.
  14. Nov 26, 2019 at 5:32 AM
    Sungod
    St Augustine
    I have been looking for something like that. A rack that you could use the roof rails.
    This is my made photoshop skill of what I was looking for -
    This would free up a ton of bed space.
    GHOST SHIP likes this.
  15. Nov 26, 2019 at 5:34 AM
    #35
    aStrauss
    Andrew
    93D4F3FA-E40A-47C4-9641-63C923E0FD91.jpg D4F7AEFA-692B-47B8-B793-59EB43501195.jpg I also have a nifty rear tire tie-down set up in mine, for bikes that fit a little better. Same would work for my Habit if the strap were a touch longer.
  16. Nov 26, 2019 at 5:56 AM
    #36
    Engineer90
    Engineer90 Active Member
    This is why I want to get a TRD OR ACLB
    abodyjoe likes this.
  17. Nov 26, 2019 at 6:10 AM
    #37
    TheUpstateTACO
    TheUpstateTACO Well-Known Member
    2018 Silver DCSB TRD OR 4x4
    Yakima Overhaul HD bed rack, Faux Pro Grill
    Take a 2x6 and cut to the bed width, treat it for the elements and place it in the notches towards the end of the bed and put the rear wheel on that. I did this on my 2013 DCSB and it worked out really well. I put a couple velcro straps on the board to keep the rear wheel from sliding around, never had issues with bouncing either. I'll dig up an old picture later to show you.
    I took a piece of aluminum angle from HD and bolted it to between the bed and front channel/track, before mounting I bolted a couple fork mounts for my bikes. Not the best picture but you get the idea.
    Big tall dave likes this.
  18. Nov 26, 2019 at 6:24 AM
    #38
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    Lol. What did you expect? Not much fits in that tiny ass bed.
    levie125 likes this.
  19. Nov 26, 2019 at 6:30 AM
    #39
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Tailgate pad
    Fork mount
    Get a long box
    mgmdclb likes this.
  20. Nov 26, 2019 at 6:34 AM
    #40
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Check out Pinkbike for your area, might be some used tailgate pads or racks for sale, save some cash that way.
    https://www.pinkbike.com/buysell/
