2G and probably 3G grease fitting for front drive u'joints.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2Gtacosr5, Sep 20, 2019.
  1. Sep 20, 2019 at 3:01 PM
    2Gtacosr5
    2Gtacosr5 [OP] Well-Known Member
    2013 double cab 4x4 sr5
    Front level kit, diff drop kit
    Greasing U-J's is easy...the front drive shaft U-J's not so...I "customized" a fitting that works "so-so"...But damn, is there a special fitting for the gun or a geometric position for "no loss and fully charged"?
  2. Sep 20, 2019 at 4:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I use a flex hose on my grease gun. (Actually bought the gun with this type hose)
    Like this : Then reach up and turn the drive shaft (front) to the best spot to slip the fitting on the zerk.
    Once you figure it out. It’s not too bad.
  3. Sep 21, 2019 at 8:02 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    They’re 90 degree fittings...Some don’t realize and try to go straight on with the gun.
  4. Sep 21, 2019 at 4:22 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    On my 06 it works best if I point the transfer case fitting at 1 o'clock then come down from above with the flexible hose.
    (Front shaft)
    TnShooter likes this.
  5. Sep 21, 2019 at 4:47 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Just pull that little plate out from under the rear joint on the front shaft. It is only two bolts and removing it gives you free access to the grease fitting on the rear joint without needing any special adapters.
    See two bolts below.
    SpanishTaco and 2Gtacosr5[OP] like this.
  6. Sep 25, 2019 at 6:23 PM
    2Gtacosr5
    Yep, I do that too..it's the UJ at the front diff..Maybe a pistol grip grease gun would work better?..I use a full cartridge gun. Gotta use both hands to grease..Maybe a small cartridge gun in one hand and the other to keep the grease gun on the fitting? Damn tight quarter's up front.
  7. Sep 26, 2019 at 3:08 AM
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    +1 for skinny flex hose on grease gun
  8. Sep 26, 2019 at 4:24 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I use a pistol grip grease gun with a lock'n lube tip. I think I put the Front D-shaft at 3'o clock to get the tip on there and pump away.
    2Gtacosr5[OP] likes this.
  9. Sep 26, 2019 at 5:19 PM
    ABNFDC
    Granite State
    I have never had a problem with that one. The front shaft spins freely, so it is easy to turn the shaft and hit it. I'm not using anything fancy, just a full size pistol grip grease gun I got about 30 years ago.
    2Gtacosr5[QUOTED][OP] likes this.
  10. Oct 2, 2019 at 6:18 PM
    2Gtacosr5
    Pistol grip..that's what I was thinking..I'll take pic's tomorrow of my "customized" tip on the fitting using a full cartridge gun. Thanks ALL!
