2gen 2wd to 4wd conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alco93, May 16, 2023.
  1. May 16, 2023 at 11:08 PM
    Alco93
    Alco93 [OP] New Member
    Daniel
    2005 tacoma trd off-road
    Okay so ima getting ready to star a 4wd swap but I was wondering if I could use a stock transmission and t case from a 4wd tacoma. My question is the wiring. I found a good deal on a whole a750f and t case combo . Thank you help is greatly appreciated
  2. May 17, 2023 at 5:00 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Your best bet is to ditch the actuator transfer case and swap in an FJ manual transfer case. Wiring is alot easier and you dont have to deal with a failing actuator at the case.
    Pittsy likes this.
