2GR-FKS (3.5L) detailed layout
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMWags, Feb 6, 2016.
  1. Feb 8, 2016 at 4:54 AM
    #41
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    The guy I replied to said he was using 91 because old timers said it burned cleaner. I then explained due to the same detergent package being used there not going to be a difference in how clean it burns. Now that I think about it though, that's not completely true. 91 requires more compression and advanced timing to properly burn which means that there's a higher chance of unburnt fuel exiting the exhaust. So in an engine designed for 87, you have a lower quality burn using 91. Does that make sense?
  2. Feb 8, 2016 at 8:53 AM
    #42
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I thought the truck is tuned for 87 but can change the timing for higher octanes if needed.
  3. Feb 8, 2016 at 10:53 AM
    #43
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    87 is the recommended fuel octane rating in the United States. We calculate octane ratings differently. The 91 is the RON (think of Europe and other areas) which is not used in the US, we use AKI which is (R+M)/2. If you get any better fuel economy from premium it's due to the fact that there is no ethanol in your fuel. I believe that varies by state though.
    Herniator likes this.
  4. Feb 8, 2016 at 11:36 AM
    #44
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I run 87 in my truck
    Rock Lobster likes this.
  5. Feb 8, 2016 at 11:59 AM
    #45
    silverbugeye
    silverbugeye Well-Known Member
    I had a 1997 V-6 4-Runner that loved 87 Octane back in 1997. In 1999 I bought a 1999 Camry that would knock/ping/ding with 87 and ran fine with 89 or 93.
    I have also seen 2000 and newer engines that have been torn down and those that ran 93 when it wasn't recommended had much more carbon build up.
    So moral of this story is... My Tacoma runs fine on 87 octane but my mileage stinks..... wait that didn't help or prove anything
  6. Feb 8, 2016 at 12:25 PM
    #46
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Mileage stinks Try running a tank of 89 and see if your mileage picks up any. Maybe your personal situation where your truck is driven and the type of fuel your running there is a ping condition and the computer is sensing engine knock backing down the timing. Wont know unless you try. All over this country there are various blends of gas and who knows what your truck does or doesn't like. You want the fuel that will give you the most efficiency with the lowest octane rating. Different brands, alcohol content or winter /summer blends can all make a difference if your trying to eek out the most mileage.
    I have found on my truck that isn't even broken in yet running around town in sport mode, 5th gear, ect off seems to help with the mileage. I haven't done any long freeway drives yet.
  7. Feb 8, 2016 at 3:59 PM
    #47
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    I've heard someone else mention that, but I haven't seen anything from Toyota actually confirming it. The inverse is obviously true with knock sensors and how it will retard timing to prevent damage. I don't think an engine is going to increase timing until it knocks and then back off.
  8. Feb 8, 2016 at 4:39 PM
    #48
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    If it were me i'd be running whatever the manual says which is regular. If you are putting in anything rated higher you are just throwing away money in my opinion. I would also buy from any retailer who has top tier gasoline. http://www.toptiergas.com/retailers/
    My manual for my jeep says to run regular and putting anything higher is not recommended. It will provide no benefit over high quality regular gasoline, and in some circumstances may result in poorer performance.
    Moral of the story, the manual is your friend.
  9. Feb 8, 2016 at 5:56 PM
    #49
    silverbugeye
    What about for an automatic?
  10. Feb 8, 2016 at 6:14 PM
    #50
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Oh my god not the stupid octane debate again... The octane rating is the fuels knock resistance rating. That's what it stands for not how clean it is, not more mpgs or power it will give you, it's how knock rsistant the fuel is.
    forty2 likes this.
  11. Feb 8, 2016 at 6:43 PM
    #51
    Johnny919
    Long Island, NY
    What?
    No kidding. I'm just reading what came out of my owners manual.
  12. Feb 8, 2016 at 6:55 PM
    #52
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Thanks for the link. :thumbsup:
    Interesting tidbits, beyond what has been posted already:
    • Oversquare design (bore > stroke)
    • Oil jets to cool bottom of pistons
    • Polymer cam covers
    • Exhaust runners cast into the head
    • 2900 psi from the high-pressure mechanical fuel pump driven off the camshaft
    I hope the oil cooler doesn't rely on a few rubber gaskets to keep the coolant separate from the oil. :devil:
  13. Feb 8, 2016 at 7:19 PM
    #53
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Did you pump her?
  14. Feb 8, 2016 at 7:50 PM
    #54
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    What? That's exactly what happens. Too much heat and you have auto ignition. I'm not sure where you think I'm wrong. Higher octane resists more heat before detention. If you run your engine in shitty hot conditions while towing in a low RPM you'll increase the chances of detention due to sub optimal engine operating conditions.
  15. Feb 8, 2016 at 8:09 PM
    #55
    KenLyns
    Belly of the Beast
    Long battery life? :devil:
  16. Feb 8, 2016 at 9:53 PM
    #56
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Stability refers to oxidation and deterioration of its octane rating.
    What you're describing is knock resistance.
  17. Feb 9, 2016 at 6:48 PM
    #57
    DrVonEvilSatan
    Toyota Truck
    Fair enough, I used wrong terms.
