2GR-FKS after it wears out...... Can this thing be stroked?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Apr 10, 2017.
  1. Apr 12, 2017 at 6:53 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Id be willing to give it a shot once my 2GR bites the dust, but at the rate shes going so far that could be a while, doesnt seem like theres much chance the engine breaks down any time soon to me
  2. Apr 12, 2017 at 6:57 AM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I'd be in the same boat. Besides, the computer stuff will have to be developed. If I end up with this truck that long, I'll probably go that route if the aftermarket is developed.
    stevotivo12[QUOTED] likes this.
  3. Apr 12, 2017 at 7:48 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Better toss some sand in the oil sump and remove the filter if you want to wear it out before 300K!
    I don't think the full potential of the current configuration is even realized yet due to the ECU TBW maps and other controls. I say this because its so obvious that there is more there when you feel power steps as the revs build. Accelerating in this truck feels a bit like the Back to the Future III train when Doc starts throwing the colored logs in!
    godwinaustin and MoneyMan55 like this.
  4. Apr 12, 2017 at 8:24 AM
    stevotivo12
    Stephen
    No kidding bro. The taco is an engine tune away from smoothing out power delvery as you say and getting back all the losses resulting from the pseudo-Atkinson cycle BS until 3000ish RPM. Id expect to gain a LOT of low end from such a tune.
    godwinaustin likes this.
  5. Apr 12, 2017 at 6:12 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    If you swap out parts. You done nothing but create the engine just removed the parts from. I know nothing about two engines we are discussing. But, as long as the specs on crankshaft dia. are equal, rod specs are equal it would not mean much. You would have to determine too if either engine is balanced differently from other. Such as internal or external balanced. When you start talking stroker engine that is when you have crankshaft stroke changes like from a stock crankshaft stroke to say a .250 gain in stroke. Then you have to adjust the rod length or piston pin location on piston. Longer rod or crank keeps the piston closer to top of bore. Which creates more torque an horsepower. Longer stroke creates more torque an cubic inches.
  6. Apr 12, 2017 at 7:36 PM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Somewhere I have an old hot rod magazine with an article about making a 360 ci small block Chevy.
    Starting with a 400 small block, which has a 4.125" bore, swapping out the crank from a 327 (3.25" stroke) and longer connecting rods. There was quite the interest in the longer rods providing a longer dwell period which increased mechanical output efficiency. The guy seemed to know what he was talking about. Back in the early 80s I was into rebuilding small block Chevy engines. In those days I had a 1975 Monty Carlo with a 69' 307 ci I taken from an old pickup. Swapping engines and parts in those days was much easier... no Computors and such.
  7. Apr 12, 2017 at 8:14 PM
    Woodrow F Call
    Colorful Colorado
    We actually covered a bit of this earlier.
  8. Apr 12, 2017 at 9:30 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    If it comes time for a new engine, and I want to keep dumping money into this thing. I'd just look for a 5.7 to shoehorn into it, might as well go for the V8 with all the extra work to bore and stroke the 3.5.
  9. Apr 13, 2017 at 4:32 AM
    SWB Tacoma
    Arkansas
    I wish Toyota would come out with a 4.0 that gets 26 MPG. Make about 300 HP at wheels. That not asking for a lot.
  10. Apr 13, 2017 at 5:05 AM
    Naturalness
    Naturalness Well-Known Member
    Andrew
    Vermont
    2017 MGM OR DCSB
    Rods are powder metal, not forged.
    Some of the sister variants of this engine have slightly different tunes. For example, the Camry, Avalon, and ES350 have 268hp, the sienna has 296hp (yes, the minivan has more power...), Highlander and IS350 have 306hp, and the GS350 has 311hp. All the same 2GR platform. So yes, it's tunable (once the ecu is unlocked).
    Side note - supercharging the Atkinson (or pseudo-Atkinson) cycle engine is the equivalent of a Miller cycle engine, which VW is trying out. Supposed to be better than supercharging a regular Otto cycle. We'll see.
    HutchJ and stevotivo12[QUOTED] like this.
  11. Apr 13, 2017 at 5:17 AM
    stevotivo12
    Stephen
    It would be better in that it would be more efficient by a long shot than a supercharged Otto cycle which is a plus. I would think power output would be the same if not a little more thanks to better parts in the 2gr fuel system than the 1gr, but I wouldn't expect more power out if the Atkinson cycle except in the sense that it had less power to start with and now might end up with the same or a tiny bit more thanks to newer, better supporting components.
  12. Apr 13, 2017 at 5:24 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Why not just go with a supercharged Lexus v8 ????
    Naturalness and stevotivo12 like this.
  13. Apr 13, 2017 at 5:29 AM
    stevotivo12
    Stephen
    Might still do that or go straight LS/T56, just exploring options as a mental exercise more than anything really
  14. Apr 13, 2017 at 5:32 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    LS motors are old outdated technology , supercharged LT4's are better !!
  15. Apr 13, 2017 at 5:47 AM
    #35
    Naturalness
    Andrew
    Vermont
    2017 MGM OR DCSB
    I'm in favor. But Toyota is pretty much done with superchargers. Turbos are the new supers.
    The new LS500 will have a twin-turbo v6, putting out some pleasing numbers.
  16. Apr 13, 2017 at 5:47 AM
    #36
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
  17. Apr 13, 2017 at 5:48 AM
    #37
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    On old LS1 engines its not uncommon to see well over 1k hp on a turbocharged junkyard motor builds
  18. Apr 13, 2017 at 6:02 AM
    #38
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    This thread wondered, but L99 with 6L80 boom.
  19. Apr 13, 2017 at 6:09 AM
    #39
    Naturalness
    Andrew
    Vermont
    2017 MGM OR DCSB
    Good reference document.
    Small distinction is on pages 10 and 11. It says the con-rods "...have been forged..." vs the crankshaft that is "...made of forged steel..."
    The con-rods start out as powdered metal, get compressed, sintered, and then a final forging step to meet final dimensions. The crankshaft starts as a solid piece of steel that is forged into the shape, with some final machining for the end dimensions.
    The difference, aside from the processing steps, is the powder metal con-rods have some porosity that allows oil to be retained and help with self-lubrication.
    Source: I've personally watched the con-rods getting produced for the 2GR engines.
  20. Apr 13, 2017 at 6:18 AM
    #40
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    When we started stroking our I4 turbos we would drop in a 2.4l crank into a 2.0l. Head, block and rods all stayed the same. Just had a piston manufacturer make custom piston to accommodate the longer stroke. Oh and high compression (10.8:1) for a turbo car because e85 is awesome sauce.
