2GR-FKS: dipstick is indicating overfill after oil&filter change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMWrdr, Feb 28, 2023.
  1. Feb 28, 2023 at 5:19 AM
    BMWrdr
    BMWrdr [OP] New Member
    2017 Tacoma SR5 Dbl Cab
    none
    Hi all,
    I'm new to the forum, but have owned a Tacoma since 2010. Just purchased a 'certified' 2017 SR5 from a local Toyota dealer in Virginia. A few days after getting it home, I checked the oil level and noticed it was registering aprox. .5" above the Hi level mark. Thinking the dealer may
    have overfilled, I drained and refilled with 6 qt. 0w20 and new filter. I ran the engine for a few minutes, turned off and, after waiting for a time, checked the oil level again. Same .5" above Hi level mark. Has anyone else seen this issue?
    Apologies if this is a repeat of a previous thread. I searched but did not find.
  2. Feb 28, 2023 at 5:25 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    The oil change from the dealer is always IMHO messed up. Mine had came back .5 low a while ago. Called dealer and they said bring it back. I declined and haven’t been back. Not sure why designers don’t make it 5,6,7 quarts with new filter. It’s like 6.3. Stupid
    bigoldbeef likes this.
  3. Feb 28, 2023 at 5:26 AM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Don’t overthink things & run it. I put 6.5qts in mine every change.
    Greg-tacoma likes this.
  4. Feb 28, 2023 at 6:06 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    6 qts gets me right in the middle on the dipstick. Half the time I dont even check it after a change
  5. Feb 28, 2023 at 7:16 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    saw a post not long ago of same issue - one TW member mentioned to compare the length of the dipstick (V6) to another (V6) - found out their dipstick was not the same length - by amount noted. Guess the dealer somehow swapped it before resale. Not sure but 4 cylinder and 6 cylinder dipsticks are not the same length. Might start with going to the dealer and doing a comparison if you don't have another owner near to assist. 6 qts puts mine to the top/max measurement. I also have a fumoto valve - makes changes easier and in your case draining excess off easier. GL.
  6. Feb 28, 2023 at 2:30 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    once you pull the dipstick oil gets everywhere in the tube and it gets hard to read.
    wait 10 mins pull it once and use a paper tower to understand where the oil is.
  7. Feb 28, 2023 at 2:34 PM
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    You are either concerned or bored. If you are concerned then use a pump to draw the excess out.
    If you are bored then keep reading a bunch of comments.
    Bcjammerx likes this.
  8. Feb 28, 2023 at 2:36 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    The dipstick was designed by dipsticks on the 3rd gen! Same dipsticks didn't put a dipstick for the tranny... :)
    This^^
    It's hard to get a good level check.
  9. Feb 28, 2023 at 3:10 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    When you did the drain and refill, I am glad you put in a new filter. Sometimes the dealer will forget the filter.
    https://www.tacomaworld.com/threads/no-oil-filter.748693/
  10. Feb 28, 2023 at 3:41 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    This stuff keep you up at night? drive more worry less.
  11. Feb 28, 2023 at 3:54 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I ran into this once after an oil change.
    I found if I left the dipstick barely popped and waited 20 minutes and went back in for a read it was basically dead on.
  12. Feb 28, 2023 at 3:57 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Dipsticks are not precision instruments. Now you know where yours registers after a 6 quart oil change. Good to go.
    Chew likes this.
  13. Feb 28, 2023 at 4:18 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    The full and low marks are something like 1.5 quarts between each other. Drop six in it and don't look back. You know, just like sex!
  14. Feb 28, 2023 at 4:57 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    you're fine. also you didn't drain the oil filter which usually take 1/2 to a full quart, I forget which. .5" over max is really nothing to fret about...imo at least, course I add 5, turn over (with new filter), and slowly add till a little below top mark...but I also do my own changes
