2GR-FKS Engine Oil Filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frank_Zuccarini, Aug 19, 2015.
  1. Aug 19, 2015 at 6:31 PM
    Frank_Zuccarini
    Frank_Zuccarini [OP] Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Has anyone seen enough of the new engine to know if the Oil Filter is on top of, or beneath the engine? Also, is it a spin-on disposable, or a replaceable paper cartridge type?
    If this has already been addressed, I apologize, but I can't seem to find it.
    Thanks........................ Frank
  2. Aug 19, 2015 at 7:05 PM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Cartridge filter on the bottom like the new 4runners.
  3. Aug 19, 2015 at 9:03 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Jeff Lange hasn't told us yet, so we don't know
  4. Aug 19, 2015 at 10:15 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Yes, it is on the bottom of the engine, and is a cartridge type like the Dual VVT-i 1GR-FE in the 2010+ FJ Cruiser and 4Runner.
    It is however the smaller filter used on the 2GR-FE and not the larger filter used on the 1GR-FE or 2GR-FSE.
    Part number is 04152-YZZA1.
    Jeff
    TopherWV and 7GR like this.
  5. Aug 20, 2015 at 3:46 AM
    thepinktaco
    Cody
    Orange, MA
    I really wish they didn't put it underneath. Removing the skid plate sucks on the 4runner and assume they didn't design the Tacoma any better. Tundras you can get to when they have plow frames on and have to take out the cross bar to get at it.
  6. Aug 20, 2015 at 4:07 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Yuck! Is it really a cartridge filter, not a canister?
    Any drain bolt, or does the oil just come out all at once, like a Tundra, and splatter everywhere?
  7. Aug 20, 2015 at 4:19 AM
    border411
    border411 Well-Known Member
    On my in-laws highlander there is a drain hole to let the oil out, then you take off the actual filter housing.
  8. Aug 20, 2015 at 4:25 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    My wife has a 2010 4runner and it is a pain in the ass to change the filter out. Its easy to get to but the process of removing the drain insert thing, letting it drain, and then removing the filter cover to only to have a large amount of oil spill out all over your arm and the skids. It's very messy because if you don't want to have oil dripping from your skid plates for the next week you have to get in there and wipe it all up.
  9. Aug 20, 2015 at 7:24 AM
    Jeff Lange
    Calgary, Canada
    It has a drain plug.
    Jeff
  10. Aug 20, 2015 at 8:13 AM
    SharkyPR
    SharkyPR Well-Known Member
    Central Florida
    2009 Civic Si
    All bolt ons + tuning solution. Capable of running high 13's.
    Find a 2006..2011 Civic SI (the one with the 2.0lt DOCH engine and 6speed manual).
    Do an oil change.
    I will assure you that it will be a selling point after that experience.
    Vantage likes this.
  11. Aug 20, 2015 at 8:27 AM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    Those guys at Jiffy Lube should be able to figure it out... Just take it there ;)
  12. Aug 20, 2015 at 8:32 AM
    SharkyPR
    Central Florida
    2009 Civic Si
    I don't trust any of them.
    Worked in that field for many years, I have my own reasons to avoid them.
  13. Aug 20, 2015 at 8:32 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Yeah, they'll just bang on the frame a few times to make you think they changed the filter. I never get the local lube place to change anything but they've been caught a few times leaving the old filters on and just changing the oil.
  14. Aug 20, 2015 at 9:01 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Dealers are not that much better. Best is to do own oil changes. On 2Gen truck those are uber easy. ON cars with cartridge at the bottom, and a need to remove skid plate are unnecessary cumbersome.
    Wow tiny filter for cute engine :D
  15. Aug 20, 2015 at 10:00 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    I know and it works great for draining 25% of the oil out of the filter case. The other 75% however, drains out all over the place.
  16. Aug 20, 2015 at 12:59 PM
    Frank_Zuccarini
    Frank
    Chicagoland
    Thank-you very much gentlemen. I appreciate the help.
    Frank
  17. Aug 21, 2015 at 4:11 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I hope it is easier to change than my 2012 4Runner was, that was a real PITA with the cartridge filter under the front end.
    It will complicate the design of skid plates (as it does on 5th gen 4Runner). I agree with the comment that the filter location on top front of the 1GR is ideal.
  18. Aug 22, 2015 at 3:36 PM
    tpak
    tpak Well-Known Member
    chris
    Colorado
    '16 DCLBOR JBL 4x4 Blazing Blue FTMFW
    This seems like it is screaming for an aftermarket solution ... any known solutions for the other motors with this style of filter? Also, why do this as opposed to cartridge type?
  19. Aug 22, 2015 at 4:06 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Haha I had an 06 Si.
    Did the first oil change. Honda did them after that.
  20. Aug 22, 2015 at 4:50 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    +1
    Neighbor got a new engine in his taco thanks to someone not tightening a drain plug.
