2GR-FKS failure at 150K, looking for input/some questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodythebluetaco, May 10, 2021.
  1. Oct 23, 2024 at 6:10 AM
    #341
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    helps to have the stick and keep it in lower gears longer too
    Junkhead[QUOTED] likes this.
  2. Oct 23, 2024 at 8:27 PM
    #342
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are correct sir.
    Although the same came be done using S-mode on the ATs. :)
  3. Oct 24, 2024 at 7:45 AM
    #343
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I've got like 50k towing on my AT and have never really had too many complaints regarding power when towing within the trucks capabilities. Could be better, could be worse.
    Junkhead and usmc2msu like this.
  4. Oct 24, 2024 at 12:16 PM
    #344
    Woodythebluetaco
    Woodythebluetaco [OP] Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    Maintenance info is definitely helpful context.
    Honestly, I disagree with your last point about not wanting to pull more from the power-plant, though. The 2gr-fks is definitely capable of pushing more power reliably. You can look to the other applications of the motor for reference, the Sienna, Camry applications push 311 hp on stock components Lexus closer to 340. With some tuning that can be bumped higher, just need to account for greater wear risk.
    I'm sold on what caused the issue: oil cavitation at the pickup tube causing under lubrication leading to failure over time. Same issue that's been known on the 2gr platform for some time. For me it was dry starts due to being parked on an angle with driver side higher than passenger side. Fo off-road folks it'll be high angle driving, performance folks high bank turns.
    Surge protection in oil delivery will help protect against pressure loss, oil catch at pct and ccv will help prevent ascis failure. I've been going whole hog post rebuild and this truck can definitely party.
  5. Oct 24, 2024 at 9:41 PM
    #345
    JohnnyTRD06
    JohnnyTRD06 Well-Known Member
    2017 Tacoma TRD Pro
    Smoked WeatherTec rain guards Access roll up bed cover Tinted front side windows TRD Cold air intake TRD Billet oil fill cap Spartan X Customs hood scoop lightbar Meso Customs dual mode LED interior lights Meso Customs V1 mirror turn signal lights Meso Customs sequential taillights Meso Customs puddle lights and switch kit Putco Nitro Lux LED headlights CBI Off-Road rear skid plate CBI Off-Road gas tank skid plate Kicker DS series door speakers Kicker dash tweeters Overland Tailor Tuning tune
    My engine was absolutely bone stock, other than having the TRD intake and exhaust because it's a Pro.
    Oil was changed every 5k, Toyota Brand or Mobile 1, nothing else and only Toyota Brand filters.
    The only thing I could possibly think of...is the original intake suffered an ACIS flap failure and let the flap rattle around in the intake. But the engine never ingested anything, I caught the bushing on top of the valve before any damage was done.
    I have a whole thread created about that issue, the symptoms, and the diagnosis on how I found out that's what it was and how I fixed it.
    But what caused my engine to fail was something else entirely. It was an apparent oil pump failure due to debris in the oil from a failed part.
