2GR-FKS Horsepower Variations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GTGallop, Mar 14, 2025.
  1. Mar 14, 2025 at 3:17 PM
    GTGallop
    GTGallop [OP] Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    According to Wikipedia.....
    The 2GR-FKS is a 3.5-litre (3,456 cc), 24-valve DOHC (with VVT-iW and VVT-i) V6 engine that combines the D-4S system from the 2GR-FSE with the simulated on-demand Atkinson cycle used in the 2UR-GSE and 8AR-FTS engines.[13] The 2GR-FKS and the 2GR-FXS selectively use direct and port injection.[14][15] This engine first appeared in the 2015 Lexus RX 350.
    Applications (calendar years):
    So looking at this some 2GR-FKS like the one in the Tacoma puts out 278 HP, but the Lexus GS 350 gets 311 HP. I notice Torque isn't listed. Give or take that's 30 HP. What is the difference? Why not put the 311 version in all vehicles?
  2. Mar 14, 2025 at 3:26 PM
    007YO
    007YO Member
    ne ohio
    2020 offroad
    why is cuz thats how every manufacturer wit evry engine they make depending on application , like car , truck , or sports car . and what is usually somehwer in top end like heads valves cam and or sometimes pistons
  3. Mar 14, 2025 at 3:27 PM
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    Different ECU tuning and most likely changes in manifold or exhaust design for different applications. Same engine but much different applications. The 2gr's feel very different in the cars based platforms like the highlander or gs350. They rev quicker and feel much less truck like. They most likely tuned the 2gr in the tacoma for max durability. Knowing owners would be pushing these engines to their limit off-road, towing and adding a lot of weight to the platform, Toyota designed them to meet higher durability standards in testing. Perhaps limiting it to 278 hp was intentional for times when you need to keep the truck at 5,000 rpm for extended periods of time.
    GTGallop[OP] and JustDSM like this.
  4. Mar 14, 2025 at 3:28 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    From a 30K ft view: Different intake manifolds and calibrations. The intake manifolds effectively tune where in the RPM band the motor produces peak torque. The calibration differences are calibrated for the intended use of the vehicle and specific fuels. The higher output motors are tuned to be "Premium Fuel" centric.
  5. Mar 14, 2025 at 6:17 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    TW user Tech708CC put Camry intake on Tacoma. He got a decent power out of the swap and the tune
    GTGallop[OP], t0p_d0g and Toy_Runner like this.
  6. Mar 15, 2025 at 6:47 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Well for one, the Lexus versions require 93 octane fuel. This implies they have higher compression and/or are tuned differently. The downside is that you pay a lot more for gas, but Lexus owners are happy to pay it.
    GTGallop[OP] likes this.
