2GR-FKS on 91 octane: 311hp@6400rpm and 280lb-ft@4800rpm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 7GR, Aug 16, 2015.
  1. Aug 16, 2015 at 11:12 PM
    7GR
    7GR [OP] Well-Known Member
    GSJ15W
    Now I don't know if this 91 octane tune is available on the new Tacoma engine, but apparently the same engine is going into the 2016 Lexus GS 350 (and probably the new RX 350).
    Just found a new entry under 2GR-FKS sub-topic on the GR engine wiki page, but the source seems to be legit this time (straight from Lexus press release).
    https://en.wikipedia.org/wiki/Toyota_GR_engine#2GR-FKS
    Lexus GS press release can be downloaded from this page
    http://pressroom.toyota.com/article_display.cfm?article_id=5183
  2. Aug 16, 2015 at 11:30 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I don't want that much horsepower. The V6 in the Tacoma is better
  3. Aug 16, 2015 at 11:31 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You seem to have all the answers about the 3rd gen... :rolleyes:
    crispy77, GotToyota, MarX and 7 others like this.
  4. Aug 17, 2015 at 12:46 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Toyota probably just limits the rpm horsepower and torque for reliability purposes. Just a change in software and you could very well get those numbers on premium. Everything else about it just being the corporate 3.5 with the Lexus line add ons has proven to be true. After all, the 4.0 has the same bore from what I have read and is essentially a long stroke version of the 3.5 . They are all in the same family.
    https://en.m.wikipedia.org/wiki/Toyota_GR_engine
    Rick111, specter208 and TacoFister like this.
  5. Aug 17, 2015 at 12:56 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    D4-S engines generally have a very high compression ratio and react very well to increased octane. Pretty much most modern engines have at least two maps (low octane and high octane). Most companies don't want their cars/trucks to be 91 octane recommended so they dyno at 87 octane.
    I would not be surprised if the 2016 Tacoma has a "high octane" map and posts similar numbers with 91/93 octane.
    Junkhead and GotToyota like this.
  6. Aug 17, 2015 at 1:14 PM
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    The 1GR did in fact make more power on 91/93. It even states it in the owners manual
    Rick111 and MTopp like this.
  7. Aug 17, 2015 at 1:53 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Wait, so it is minivan / car engine ? Otherwise why would you think car engine specs would apply to truck engine ...o_O
  8. Aug 17, 2015 at 2:57 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^This. It takes time to adjust to the octane.
    Most companies have a high and low octane tune. Toyota generally does. The 2GR will react even better to high octane and the 1GR.
    Junkhead and MTopp like this.
  9. Aug 17, 2015 at 3:10 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Don't use wiki :notsure:
    You might be right but most of the time, newer model cars with have multiple timing maps; at least a high/low octane map. It takes a while for the ECU to adjust so you won't notice an immediate difference and generally the difference was at higher RPM's so you didn't notice it when daily driving...
    Direct injection engines benefit a lot with higher octane gas. Generally timing is tuned way do to accommodate lower octane gas in order to make it more appealing to buyers.
  10. Aug 17, 2015 at 3:11 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Sorry that's a different engine, it may pull harder with better gas but your not getting 30 hp from any gas and a factory tune..... I wish it would be that easy... But with some aftermarket tuning it should be close to that.... You can unlock about 20-30 hp with these V6 Toyotas..... Hopefully that will be true on the new engine...
  11. Aug 17, 2015 at 3:13 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Def false, it does make more power with higher octane, its been that way since 2005.
  12. Aug 17, 2015 at 3:14 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Go on......... :D
    MTopp and bdunna like this.
  13. Aug 17, 2015 at 3:36 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    -Yes, there is generally a high and low octane map. ECU can "learn" as well
    -I don't know what an octane sensor is but that's not how ECU's detect octane. The ping sensor detects all detonation and the ECU can map the detonation timing to the piston position (using crank sensor inputs) and determine if detonation is advancing or retarding. At certain trip points, it will change its octane map. At other trip points, it will cut all timing due to pinging.
    -The FSE has almost a 12:1 compression ratio. 91 octane can easily make 30hp over 87. The port injection is used simultaneously with the DI for low and mid engine speeds to help atomize the fuel air mixture. The port injectors also help with emissions.
  14. Aug 17, 2015 at 4:11 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
  15. Aug 17, 2015 at 4:46 PM
    7GR
    GSJ15W
    Hey, I found this info and was just sharing with fellow TWers. This thread can serve as a good discussion thread about the new engine if you try to at least act like an adult by cutting back on the trolling/snarking.
  16. Aug 17, 2015 at 4:57 PM
    7GR
    GSJ15W
    True about the knock sensor advancing or pulling ignition timing depending on the whatever the fuel's octane will allow prior to preignition/detonation.
    Let's see if any new Tacoma owner is planning to do some dyno runs to compare power and torque when running different octane fuels.
  17. Aug 17, 2015 at 5:12 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    We should call him BlueTroll.
    7GR[QUOTED][OP] likes this.
  18. Aug 17, 2015 at 5:13 PM
    7GR
    GSJ15W
    Need more info on the Tacoma engine and the GS engine, to see if there are any physical differences among the engine block and components. If not, then this may well be just a tune difference.
    They actually do tune an engine for different octane levels, but they usually do it backwards, where they'll tune for premium 91 octane which is usually recommended or required for high performance engines, and then tune for 87 for pulling back ignition timing and such if the owner has no choice but to use 87 temporarily.
    In the case of the Tacoma's engine, it's most likely tuned for 87 octane, but the tuning might accommodate more timing advance in the presence of higher octane fuel until the knock sensor senses knock to halt further timing advances.
    Another thing that I wish we have more info on is whether the rated horsepower and torque figures derived from running strictly Atkinson-cycle? If the engine can in fact instantaneously switch over to Otto-cycle with VVT-iW, then I'm very curious as to the actual power and torque curves when running in Otto-cycle, which means you sacrifice fuel-efficiency for performance.
    StAndrew likes this.
  19. Aug 17, 2015 at 5:40 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Don't be a nimby. Google it. I don't know about any dyno but I know the ECU is much more careful and much slower to advance timing for higher octane fuel and very quick to pull timing for lower octane fuel.
    This.
    Before the trolls run out, Im not disagreeing, Im just saying its quite possible :notsure:
  20. Aug 17, 2015 at 6:40 PM
    7GR
    GSJ15W
    No problem, all these are really just conjectures at this point. Probably a good thing to bring up in case some people who are curious but with the resources to find out can actually go find out for the rest of us. Unless Toyota is willing to spill the beans, but they might not be so willing to divulge corporate IPs such as engine tuning strategies.
