2GR-FKS on 91 octane: 311hp@6400rpm and 280lb-ft@4800rpm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 7GR, Aug 16, 2015.
  1. Aug 17, 2015 at 6:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    because you can advance timing more on higher octane to overcome the "resistance to detonation" and possibly make more power.
    Ill be very interested to see what dyno charts look like on this motor, if it puts down the numbers they claim and has a VERY broad torque curve, more so than the 1GR its going to be a WINNING motor.
    7GR[OP] likes this.
  2. Aug 17, 2015 at 6:57 PM
    7GR
    7GR [OP] Well-Known Member
    GSJ15W
    That's why only an engine whose fuel injection and ignition timing strategies can react to whatever feedback gathered by the knock sensor can benefit from using fuels of different octane ratings. For some cars that are tuned strictly to run 87 octane, putting 91 or higher in the tank would be a waste of money. For a car where the manufacturer recommends premium fuel but not required, this is when running 91 may gain better performance or fuel economy compared to running 87, especially in hot summer days.
    FYI, the higher the octane rating, the higher resistance to detonation (which was true as what you just said), which means the ignition timing can be advanced (prior to the TDC of the power stroke out of the 4 strokes) that results in more power. The ignition timing is programmed such that it will always advance as much as possible until the knock sensor senses knocking/pinging, which will then either halt the timing advance any further, or cut back the advance (aka retard the timing). All of these actions are constantly being relayed and communicated back and forth with the ECU/PCM to compare with fuel trim strategies as well as other mappings/data for more on-the-fly adjustments.
    rlx02 likes this.
  3. Aug 17, 2015 at 7:04 PM
    7GR
    GSJ15W
    I'm more likely to believe that the power and torque figures given are under the Atkinson-cycle, since that is how Toyota is marketing this engine as. I think this new engine runs on Atkinson-cycle almost all of the time, until higher load (based on crank speed, throttle-angle, etc) or wide-open-throttle input is detected which will then command the VVT-iW intake cam to cut back on the post-BDC angle at the beginning of the compression stroke, thus minimizing the Atkinson effect of scavenging the fuel-air mixture back into the intake runners.
  4. Aug 17, 2015 at 9:56 PM
    BeaverNation
    BeaverNation Well-Known Member
    Can this engine run E85? similar engine to frs and it can. Would be fun if this engine could add 40-50 hp and 30 tq with headers intake and tune like the frs.
  5. Aug 17, 2015 at 10:36 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Why the eff would anyone willingly put E85 in their vehicle?
  6. Aug 17, 2015 at 10:42 PM
    BeaverNation
    Cause it rips, and newer engines that can run it don't have issues. it would just be a tank every once and a while for me. Was the colorados numbers on regular or premium?
  7. Aug 17, 2015 at 10:50 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Your logic is flawed. You can't just drop a tank of e85 in and expect positive results. A stock tune would not like that. The IDC probably wouldn't even be able to handle the extra fuel necessary to make a lot more power. I can't recommend it.
  8. Aug 17, 2015 at 10:57 PM
    BeaverNation
    Flex fuel sensors come with the e85 tune frs/brz
    Rick111 likes this.
  9. Aug 18, 2015 at 12:28 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Use 2 bottles of octane boost to get 33 additional HP.
    Junkhead likes this.
  10. Aug 18, 2015 at 5:33 AM
    Quentin
    Quentin Well-Known Member
    Eleanor, WV
    2016 Toyota 4Runner Trail Edition, KDSS
    I don't think the GS350 is using the 2GR-FKS. I believe it is a tweaked 2GR-FSE.
  11. Aug 18, 2015 at 6:44 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Only the best for your whip
  12. Aug 18, 2015 at 7:29 AM
    7GR
    GSJ15W
    The current GS 350 still uses 2GR-FSE. The 2016 model will switch over to 2GR-FKS.
    Read the press release (I provided the link in the 1st post), it says right in there "2GR-FKS".
  13. Aug 18, 2015 at 8:15 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The 2GR-FKS is a tweaked 2GR-FSE. The only difference is the FKE can switch between Atkinson cycle and Otto cycle while the FSE is strictly Otto cycle. This is why I wouldn't be surprised if the Tacoma can net around 300hp with 91/93 octane.
  14. Aug 18, 2015 at 8:21 AM
    trexTRD
    trexTRD Well-Known Member
    California
    Fox All Around, MaxTracs, Black & Red Leather Seats, Straight Pipe, and other crap...
    Sooo I'm a little late to this but are you guys saying the 1GR-FE is actually doing better with 91 or higher octane?
  15. Aug 18, 2015 at 8:24 AM
    #35
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    FYI, for those that are interested. Toyota ECU for the 3S-GTE Turbo (90-99 MR2). Not new technology.
    7GR[OP] likes this.
  16. Aug 18, 2015 at 9:32 AM
    #36
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Interestingly, the specs for the 2GR in the Tacoma (278/265) list it as using 91 octane fuel.
    Jeff
  17. Aug 18, 2015 at 10:00 AM
    #37
    Jeff Lange
    Calgary, Canada
    Looking closer, it looks like it was 91 RON, so it should actually be 87 R+M/2 for the Tacoma, not premium.
    Jeff
    jonnyozero3, border411 and 7GR[OP] like this.
  18. Aug 18, 2015 at 11:27 AM
    #38
    7GR
    GSJ15W
    Less so for the single VVT-i engine, and more so for the dual VVT-i engine that Tacomas don't get.
    I have yet to try it on the FJ with higher octane fuel, but it's been told that you can gain roughly 20 horsepower and 20 torque using 91 octane, and this is without VVT-iW or D-4S tech.
  19. Aug 18, 2015 at 1:49 PM
    #39
    Quentin
    Eleanor, WV
    No shit. I didn't see that. Odd that they left the 2GR-FSE in the IS350 and put the 2GR-FKS in the GS350. They are certainly very different engines based on my source (side by side you wouldn't confuse the two according to my source). I wonder if the IS300 is getting a 2GR-FKS or a detuned 2GR-FSE...
    Tacoma is getting a Lexus car motor! :lol:
  20. Aug 18, 2015 at 4:23 PM
    #40
    Evintos
    Evintos New Member
