2GR-FKS V6 Plastic Engine Cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by godwinaustin, Aug 11, 2018.
  1. Aug 11, 2018 at 4:46 PM
    godwinaustin
    godwinaustin [OP] Well-Known Member
    Jon
    WYO
    2004 4x4 5VZ + 1982 4x4
    Although initially, I think I prefer the 1GR, the 2GR-FKS on my 2018 does not seem too bad, although time will tell through abuse and durability how good it is.
    I removed my plastic engine cover as I am philosophically opposed to them in general and just see it as something that will get in the way of wrenching on it down the line. I see the insulation on the bottom of the cover...is that for sound deadening only, or does it act as a temperature insulator for the manifold? Id rather do without it, but dont want to mess with engineering dynamics. Thanks!
  2. Aug 11, 2018 at 4:57 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    ... couldn't you just remove it when wrenching "down the line"?
    BSFord, specter208, Ch78 and 2 others like this.
  3. Aug 11, 2018 at 5:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The cover pulls off in a few seconds, then you can wrench on it.
    Lt. Dangle likes this.
  4. Aug 11, 2018 at 5:22 PM
    godwinaustin
    Jon
    WYO
    Well yes of course, but its also the idea of removing shit that doesn't actually have a legitimate function.
  5. Aug 11, 2018 at 5:52 PM
    su.b.rat
    su.b.rat broken truck
    you can. but where to stop with that? actually i don't know if there's any temp modulation from the cover, but i would seriously doubt this motor's reliability through temp control would be dependent on it. so, as you'd want to say: remove that shit.
    edit: yes it's true that i have 2 cabinets full of take-offs from my Tacoma..:rolleyes:
    hiPSI and Lt. Dangle like this.
  6. Aug 11, 2018 at 6:38 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It has a legit function... both thermal and sound deadening. Do what you want but it takes like two seconds to remove, plus it keeps the mud splashes away too.
    shakerhood likes this.
  7. Aug 11, 2018 at 6:40 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Start with the cover, remove carpet, doors, tailgate and all unimportant bits that have no function lol.
    A few bungee cords are much lighter than the tailgate. You will solve the power complaint!
    BSFord, Hank Heel, specter208 and 2 others like this.
  8. Aug 11, 2018 at 6:42 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It refocuses the sound of the motor back into the block to provide more instantaneous torque, and it also improves under-hood aerodynamics for better economy. Removing it will be a noticeable performance downgrade.
    Booleo, GoodOlBoy and hiPSI like this.
  9. Aug 11, 2018 at 7:07 PM
    mlheiman
    mlheiman Member
    2018 Tacoma TRD
    It's weird to me that my 2018 Tacoma's don't have insulation under the hood. Seems like that would help reduce engine sound.
  10. Aug 11, 2018 at 7:56 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    It also protects the stuff under it from water infiltration /rain /storm/big ass puddle/ but it has the #1/2 lbs weight drag on that +#4000lbs truck. and maybe you should only fill your gas tank 1/4 at most as the other amount over what you need, because it doesn't have a legitimate function beyond that day or two's commute. think or all the ware and tare you can save... ps the 6 time a year i open the hood and the plugs last 100K just what do you think you NEED to do under the cover ? once a year for me to clean under it .
  11. Aug 11, 2018 at 9:19 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I removed the one on my Jeep as the Jeep Hood is vented and I think it helps cool the engine compartment. With no vents on the Toyota hood, I’m not sure removing will do anything except maybe allow more engine noise to escape.
  12. Aug 12, 2018 at 6:59 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    I've always pulled the engine covers on my trucks. It lets me look for obvious issues every time I've got the hood up. I'm lazy, so removing the cover on a regular basis isn't gonna happen. Just ditching it permanently compensates for that personality flaw.
  13. Aug 12, 2018 at 7:07 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    It was the second thing I pulled off. Right after the air dam. Effects nothing.
