2in block lift, upgrade to a toytec 3in suspension?
Discussion in 'Suspension' started by SC4x4, Feb 10, 2014.
Is it worth upgrading to a 3in suspension from a 2in block lift?
Poll closed Mar 12, 2014.
  1. yes, 3in suspension
    7 vote(s)
    100.0%
  2. no, 2in block is fine
    0 vote(s)
    0.0%
  1. Feb 10, 2014 at 10:51 PM
    SC4x4
    SC4x4 [OP] Member
    Tyler
    Felton
    06 TRD Off-Road
    2in lift, Black Emblems, Big Foot tires, Appradio,
    Hey everyone, currently i have a 2in ready-lift block lift and i was looking around the forum and found that a block lift really isn't to great to have. So my question is, is it worth upgrading to a toytec 3in suspension lift? I only go out wheeling once in a while, but i don't wanna risk anything since i have a block lift. The lift i would get would include:
    Bilstein 5100 shocks all around
    Diff Drop Kit
    Top Plate Spacer
    2in AAL
    http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    For a overall lift of 3in.
    I was also looking around and saw that people really liked OME with 885coils.
    So i guess my two questions are...
    1.) is it worth upgrading to a 3in suspension lift from a 2in block lift?
    2.) would ether the OME or Bilstein 5100 lift be fine?
    Thanks for the help!:D
  2. Feb 12, 2014 at 7:23 AM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    I went with the Toy Tech 5100 lift w/Eibach springs and I'm loving it. For the full 3 in. lift you will need to add the 1/2 spacers for the double cab. I went with the 2in. AAL in the rear. It sits about a 1/2 higher in the rear. I also installed SPC Upper control arms and 265/75/16 tires. The only problem I ran into was the lower control arm bolts being seized and not being able to align it exactly to spec. It's at the dealer now having new lower control arm bushings and bolts installed and being re aligned.
  3. Feb 12, 2014 at 7:31 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. Feb 12, 2014 at 11:13 AM
    SC4x4
    SC4x4 [OP] Member
    Tyler
    Felton
    06 TRD Off-Road
    Cool yeah the link helped a lot thanks!
    Sweet truck bw4706
    I think I'm more leaning towards the 5100, seems pretty durable
