2in or 2.5in lift need pictures?
Discussion in 'Suspension' started by hockeypoor, Jun 10, 2011.
  1. Jun 10, 2011 at 9:05 AM
    hockeypoor
    hockeypoor [OP] Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    I am going to lift me 06 DCLB that has the rear tsb done. I would lift to know what will level it out? 2in? I would also like to know if anyone has a picture of a 2in with tsb speedway blue.
    What would the 2.5 with just the tsb look like? if I do the 2.5 would I also need to lift the rear to keep it level?
    Pictures of
    2in and tsb would be great.
    2.5 with tsb
    2.5 with tsb and aal or blocks. if needed?
    I will be running 265/70r17 on stock wheels.
  2. Jun 10, 2011 at 9:45 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Seems like you could just put your jack under the front and lift it the 2 or 2.5" to see what it looks like.
  3. Jun 10, 2011 at 9:51 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :ohsnap:
  4. Jun 11, 2011 at 5:26 AM
    hockeypoor
    Come on guys.
    Any help would be great
  5. Jun 11, 2011 at 5:29 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    sorry... I only have old pics at 3" w/ tsb and 1.5" aal
  6. Jun 11, 2011 at 5:42 AM
    hockeypoor
    Any pics with stock rims and 3in? How was the ride?
  7. Jun 11, 2011 at 6:34 AM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Well the colour i can not help you with, but the 2 inch pic I can.
    This pic is the front done with ome 884's and the stock rear tsb before the aal went in. Stock wheels and i thought it was close to level. 2 inch lift for the front.
    This is the competed lift , 2 in the front and just shy of 2 in the rear.
  8. Jun 11, 2011 at 9:19 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    sorry I had wheels and tires before the lift...
    3" lift (OME 885 springs, Bilstein 5100s (set to 0), Toytec 1.5" AAL, TSB springs, and LR UCAs) 285/70/17 BFG A/T and Procomp 7089 17" rims 4.5bs
  9. Jun 11, 2011 at 9:32 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    agreed there are literally tons of people on here running a 2 inch setup.
  10. Jun 11, 2011 at 8:19 PM
    hockeypoor
    Maybe I am new, Maybe I typed it into the search wrong or maybe I was just lazy.
    Either way does it really matter? I am a fellow tacoma owner that was looking for some help.
    But at least you know what you are:frusty:
  11. Jun 12, 2011 at 11:31 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    look for KPT I think he is running a 2" setup
  12. Jul 23, 2011 at 3:54 AM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    AWESOME! It seems that being a "dick" on here for some members is the norm. Yeah, you can use search and alot of times find the exact answer you may be looking for, but seems to me being a forum for tacoma's that ppl would willingly use their experience & knowledge to just provide you with an answer. If it's to much trouble for them, maybe they could just keep their mouth shut instead of being rude about it. With that said, there are MANY ppl on this site that are very helpful & COURTEOUS. Just my .02!
  13. Jul 23, 2011 at 7:40 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Exactly....if you have nothing nice to say...do not say anything at all!
  14. Jul 23, 2011 at 7:42 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Click on my sig and you will find tons of pics of my setup. Thanks for the shout out Mark.
