2inch lift on my 09 prerunner
Discussion in 'Suspension' started by Tac09oma, Apr 28, 2011.
  1. Apr 28, 2011 at 7:14 PM
    Tac09oma
    Tac09oma [OP] Member
    Clemmons, NC
    09 PreRunner
    Im new this forum and this is my first thread! Im getting a 2inch lift on my 09 prerunner 2wd but the thing is is its on a 4wd chassis
    so it sits higher than the 2wd chassis .... questions are... where can i get a 2inch kit that will work... and whats the biggest size tires i could fit?
  2. Apr 28, 2011 at 7:16 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    bilstein 5100 shocks set at 1.75" or 2.5" (might need to get UCA's with the 2" option) and a AAL in the back that should raise it either 1.5" or 2" wether you get the TSB option or not
  3. Apr 28, 2011 at 7:18 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    if he goes with the billies set at either 1.75" or 2.5" he wont need ucas. but 2.5" is about the highest you can go with out needing them though. also maybe look at the rancho quicklift :crapstorm:
  4. Apr 28, 2011 at 8:08 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You've got many options.
    1. What do you plan to do? just looks? highspeed desert runs?
    2. How much do you want to spend? What's the most you'll spend on it?
    Tires: you can fit the equiv of a 32" tire without modification, you can fit the equiv of 33" tires with aftermarket wheels/ or spacers, and some minor trimming.
  5. Apr 28, 2011 at 8:11 PM
    Tac09oma
    Clemmons, NC
    09 PreRunner
    Thanks guys... Im not familiar with UCA or TSB? WHat size tires you guys think i can fit?
  6. Apr 28, 2011 at 8:14 PM
    Tac09oma
    Clemmons, NC
    09 PreRunner
    Just looks for now.... I have a Jeep i do off road stuff with,,, like to spend around 300-400. Thanks!
  7. Apr 28, 2011 at 8:15 PM
    Tac09oma
    Clemmons, NC
    09 PreRunner
    BTW This is my first Tacoma so Im new to the whole deal lol
  8. Apr 28, 2011 at 8:19 PM
    nvdeserted
    Reno, NV
    Well amigo, start using the little search box on the main page of each sub-forum. There is a TON of info on all this stuff. Pretty much every single thing you can possibly do to a Tacoma is documented on here somewhere.
    Does your Taco have 16" or 17" wheels?
  9. Apr 28, 2011 at 8:19 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    UCA: upper control arm
    TSB. Toyota Service Bulletin?
  10. Apr 28, 2011 at 8:29 PM
    Tac09oma
    Clemmons, NC
    09 PreRunner
    16inch... Btw I would wanna lift where i can install it and ride... i dont wanna get into changing a bunch of things like UCAs and extending driveshaft stuff like that... how high can u go before u have to do some of that stuff? Thanks!
  11. Apr 28, 2011 at 8:54 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    anything higher that 2.5 inchs, Upper Control Arms (UCA) are highly recommended
  12. Apr 28, 2011 at 8:55 PM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
