2JZ 2nd gen tacoma 4x4!
Discussion in 'Tacoma Videos' started by jimbo808, Feb 10, 2013.
  1. Feb 10, 2013 at 5:23 AM
    jimbo808
    jimbo808 [OP] Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, pelfrey ifs skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
  2. Feb 10, 2013 at 12:09 PM
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    I would think you could get 535 out of the 4.0.
  3. Feb 10, 2013 at 1:29 PM
    x2468
    x2468 Well-Known Member
    Tallahassee
    '02 TRD 4wd V6 Xcab Sr5
    There's a guy over on customtacos that has a twin turbo 2jz in his 4x4 98 making similar power.
    You probably could get 500+hp out of the 4.0 but it would be really expensive, since i don't think anyone makes the parts for it, and even then you wouldn't know how long it would last, since it hasn't been done very often. with the 2jz there aren't really any unknowns. The parts are abundant, the knowledge is out there, and everyone knows it has the strength to handle the power.
  4. Feb 10, 2013 at 1:39 PM
    allmotorrex
    allmotorrex Grove Street Fabricating
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    That's pretty tight but that is a horrible video. Really a pointless video. They could've at least showed the dyno sheet or dyno it in 4wd
  5. Feb 10, 2013 at 5:01 PM
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
  6. Feb 11, 2013 at 1:35 AM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    06 double cab PreRunner
    Man that is just jaw dropping
  7. Feb 11, 2013 at 2:18 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    fuck that, money wasted that could go towards other things.
  8. Feb 11, 2013 at 4:42 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    It would be a lot cheaper actually.
    Fab Turbo Mount just behind the y-pipe, fab IC piping, $200 ebay IC, injectors, tune, big ass precision turbo.
    Even if you plop the block it would still be cheaper.
  9. Feb 11, 2013 at 3:02 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    i have wanted to do this either to my truck or an xrunner for so long and didnt know if it was possible but i now i know it is so hopefully i can save up and do this within the next few years
  10. Feb 11, 2013 at 3:05 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
  11. Feb 11, 2013 at 3:22 PM
    jberry813
    jberry813 The Mad Scientist
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Different strokes for different folks. Some would argue the ring you got for your girl was "money wasted that could go towards other things".
    The 2JZ is one of the most impressive and stout motors Toyota ever came out with and the tuning aftermarket is endless. Much more so than the 1GRFE that's for sure. And without knowing the history of who built it, what happened to the old motor, how they aquired the 2JZ or any of the other history, saying it's a waste of money is kinda near sighted.
    Mademan925 likes this.
  12. Feb 11, 2013 at 4:35 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    So is it a race truck or an off road truck?
  13. Feb 11, 2013 at 5:57 PM
    Clifford
    Clifford Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Not on stock internals, and if you did hit that power level, it wouldn't last.
    You could hit that power level on the stock motor, thats pretty much it's limit, and how safe it would be over a long period of time would be anyones guess. You can hit close to 500 if not right at 500 with URD's MKIII set up. With proper upkeep, you can roll in the mid 450's all day long though.
    Only down side to the 2jz swap would be the added weight. Other than that you are spot on.
    If you are going to spend the money on a custom turbo kit, don't cheap out on the kit with a ebay IC. My custom kit cost 6k, all quality parts, will support 700+ hp. You get what you pay for.
    This, it's all about what the owner wants out of their truck.
  14. Feb 12, 2013 at 11:40 AM
    x2468
    Tallahassee
    probably DD/ some off-road, given the guy went through the trouble of keeping 4x4. plus he has MTs
  15. Apr 22, 2013 at 1:29 AM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    Thats so sick! i have been thinking of it but i would try it with twins, and for everyone thats says its pointless heres my answer, dont do it..also you get get to 700+ HP out of a 2JZ and still be reliable. If i ever do get it done i shall call it TRD Sport MK5 :D
  16. Apr 23, 2013 at 10:56 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
  17. Apr 23, 2013 at 11:11 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  18. Apr 23, 2013 at 4:12 PM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    forget that...thats why you leave the truck alone and just own a Supra as well. :)
  19. Apr 23, 2013 at 5:16 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Deck Plate Mod; Grey Wire Mod; 1.5" AAL; 1.75" Lift Shackles; Bilstein 5100's; Eiback Coils; LR UCA; Front Diff Drop; Tundra Brake Upgrade; Wheels Offroad Brake Lines; Rear Diff Breather Mod
    Be tons cheaper to build the 4.0. And you'll get more torque and a better low/mid range power band :notsure:
  20. Apr 24, 2013 at 5:17 AM
    93civEJ1
    09 DC TRD OR
    Build it with what parts? lol...you make it sound like theres a ton of 4.0 tacoma motor parts out there.:confused:
    usptwins likes this.
