2JZ 2nd gen tacoma 4x4!
Discussion in 'Tacoma Videos' started by jimbo808, Feb 10, 2013.
  1. Apr 24, 2013 at 5:19 AM
    Large
    Large Red
  2. Apr 24, 2013 at 12:12 PM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
  3. Apr 24, 2013 at 12:17 PM
    93civEJ1
    09 DC TRD OR
    Sorry,
    Just dont really see the point on a tacoma unless it was to help with off road.
  4. Apr 24, 2013 at 1:59 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^Right. But, don't forget that building a reliable turbo motor goes beyond just performance parts, or pistons/rods even. The beauty of a 2JZ is the fact that the block and head can handle the pressure and heat generated. Boost combined with the inline motor's torque curve makes it very successful. So you've got to think about parts/fabrication, available tuning, heat dissapation, air flow (think manifolds, valves, routing your IC piping with bend radius vs diameter), and internals. Also, once you've got a nice powerful motor, you've got to consider your clutch, then your trans, then your axles, etc. because they are all going to need to be upgraded as well. There's a lot to it.
  5. Apr 24, 2013 at 2:07 PM
    Lumpskie
    New Hampshire
  6. Apr 24, 2013 at 5:35 PM
    93civEJ1
    09 DC TRD OR
    Building a 2jz motor is not cheap. You dont have to do anything to a 2jz to have a stock block / internal motor easily handle 500whp.
    Mine is built to handle at least 1k.
  7. Apr 25, 2013 at 5:29 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Deck Plate Mod; Grey Wire Mod; 1.5" AAL; 1.75" Lift Shackles; Bilstein 5100's; Eiback Coils; LR UCA; Front Diff Drop; Tundra Brake Upgrade; Wheels Offroad Brake Lines; Rear Diff Breather Mod
    *sigh* At least Google what you are about to post to make sure its right :rolleyes:
    Makes more torque than the 2JZ makes HP :rolleyes:
    The 1GR will eat a 2JZ in torque/RPM any day with a comparable budget. Just look at the build ^. You cant argue with displacement :notsure:
    Now before we get out of hand, I think the 2JZ is hands down one of the best engines built to date. The Mk IV is my dream car.
  8. May 15, 2013 at 11:26 PM
    x2468
    x2468 Well-Known Member
    Tallahassee
    '02 TRD 4wd V6 Xcab Sr5
    That dude needs to aggregate the info in his build. there's no way i'm reading 50 pages of bullshit, even if it's for a 475hp 1gr
  9. May 15, 2013 at 11:59 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Cange your posts per page to 100 ;) boom! less pages.
  10. May 16, 2013 at 10:10 AM
    allmotorrex
    allmotorrex Grove Street Fabricating
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    Hahaha
  11. May 16, 2013 at 10:15 AM
    Large
    Large Red
    I happen to know him lol it's not 50 pages of "bullshit" it's really 50 pages of trial, error and ingenuity.
  12. May 16, 2013 at 10:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Where have you been??????
    I have had a built 1GR since '09. More recently things have really stepped up from vendors, and not to sound conceited even though I know it will, in at lot of ways due to what I have helped with since '09. From sending Pauter one of my rods so that I could have them made, to a block of mine being shipped from my house to Darton so that Darton Wet M.I.D. sleeves could be made as well. That first run was funded by Gadget at URD. Also more recently I sent a rod to Paul at Dezod, so that he could get a budget builder set of rods, Molnar, available to the public.
    A UAE performance shop had Brian Crower make stroker cranks for the 1GR, and until recently had sole rights to selling them. I am likely the first person in the US to have a BC 4.3 stroker kit,(Dustin would know for certain) but those are now available to the US market as well. Clifford would be another who has since purchased one.
    Engine parts from Dezod
    http://www.dezod.com/cat_engine4_all.cfm
    www.LCEperformance.com has plenty as well.
    Darton sleeved block:
    http://www.tacomaworld.com/forum/performance-tuning/238786-darton-sleeves.html
    PowerFab Automotive turbo kit:
    http://www.xr-underground.com/forum/showthread.php?t=53171
    Work with them regularly. ^^^
    First ProEFI Pro128 on a '05+ Tacoma. Toon714 is the second.
    www.proefi.com
    Let me keep a little humility though. All of this stuff that I have aided in isn't just for me or bragging right. It is to properly build a strong and reliable HP engine as well as helping the aftermarket move forward so that all of this stuff can become more readily available and cheaper for everyone. It helps us all.
    Trust me, it has already been proven that with rods, pistons, head gaskets, and head studs, a 1GR can easily be in the mid 600's. That was on a twin turbonetics XR by PSI Racing, using a Haltech, at ~28 psi. Journal bearing. All the extra stuff is just for fun or over built strength. ;)
    I need to do that. Lol. Seriously though.
  13. May 16, 2013 at 11:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Kind of. ;) But still sports truck. I had started the process to lower and strengthen. Already had a plan laid out. Then a friend showed me a build that paralleled mine.
    http://www.speedhunters.com/2012/10/gmc-scyclone-feature/
  14. May 16, 2013 at 11:22 AM
    twigme
    twigme Member
    Matthew
    Westlake Vlg. CA
    2006 TRD Offroad Crew Cab Short Bed
    Bilstein 5100s at 1.75 Color Matched Grill Pioneer DEH-3400 Dakine Bed Pad
    Holly crap, that thing would be such a sleeper rig.
  15. May 16, 2013 at 2:12 PM
    #35
    Clifford
    Clifford Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Torspd, you know that trucks will never be fast, ever or sporty. So there.
  16. May 16, 2013 at 2:14 PM
    #36
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Tell me about it...........:rolleyes:
  17. May 16, 2013 at 2:21 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    ^^^That guy hears that more than anyone I know! Even when he is on their sports car's tail.
  18. May 16, 2013 at 3:20 PM
    #38
    x2468
    Tallahassee
    But it will be faster, more powerful and more fun to drive than it was...
  19. May 16, 2013 at 3:21 PM
    #39
    x2468
    Tallahassee
    No, I'm sure it would be great fun on a rainy day with nothing to do....
  20. May 17, 2013 at 10:18 AM
    #40
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    its like u actually know what ur talking about or something :cool:
    glad ur here man, keep spreading the knowledge!
    and thank you for helping us all out :cheers:
