2jz Gte 4wd swap...
Discussion in 'Performance and Tuning' started by t_ill_er, Mar 23, 2016.
  1. Mar 23, 2016 at 5:21 PM
    t_ill_er
    t_ill_er [OP] New Member
    Tyler
    2003 1st Gen 4wd Auto
    3 inch Toytec lift, 33x12.50 Nitto Terra Grapplers, 16x8 level 8 wheels, Touchscreen headunit, custom sub box, flowmaster 40 series muffler with custom exhaust, other little details.
    I'm interested in swapping an 03 first gen 4x4, looking to either rebuild the stock 3.4 and supercharge it, or do a 2jz gte swap. I would still like to keep 4wd and would prefer to keep the truck lifted. Any insight as to what I would need in order to do the swap as far as wiring, suspension, drivetrain (transmission and axles/diff), frame modification, pretty much what to expect when doing the swap would be appreciated. Also, if theres anywhere that sells parts for this swap or any shops in MD that would do it the correct way I would like to know. I know what a complete 2jz gte motor and tranny go for so I have a budget in mind, but the main thing is doing the swap correctly with no issues. Thank you for the help!
    SSG (03)TACOMA likes this.
  2. Mar 27, 2016 at 10:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    1FZ-fe. 4.5L big brother to the 2JZ.
  3. Mar 28, 2016 at 11:27 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    HEAVY!
  4. Mar 28, 2016 at 12:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Either way.
    QMEDJoe and elnip like this.
  5. Apr 16, 2016 at 10:15 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Any updates on this? Sounds like a cool project. Other than the wiring and making custom motor mounts, it seems pretty straight forward. Would be interested in seeing how it turns out.
  6. Mar 10, 2018 at 6:48 PM
    Cody541
    Cody541 New Member
    Cody
    1995.5 Tacoma 5vzfe 4x4
    Full caged, long travel, turbocharged, race truck.
    What bellhousing did you use?
  7. Sep 30, 2018 at 4:15 AM
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
