2JZ into 2001 4X4 Tacoma Build
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2JZ_Tacupra, Sep 18, 2019.
  1. Sep 19, 2019 at 8:09 AM
    #41
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Not sure if it's power or torque that ultimately breaks an axle. Of course torque will be multiplied tremendously downstream of the crawl case...
    tacoma16 likes this.
  2. Sep 19, 2019 at 8:13 AM
    #42
    2JZ_Tacupra
    2JZ_Tacupra [OP] Active Member
    Antoine
    Houston
    2JZ 4x4 First Gen 5 Speed
    Compound turbo 2JZGTE, Marlin Crawler Dual Case Taco Box, 2010 Superduty 1 Tons
    Either way, torque curve will be higher from a new 30psi target boost pressure and advanced timing with water/meth. I will be avoiding getting into high boost when I have the cases in lo.
    randd and 3JOH22A[QUOTED] like this.
  3. Sep 30, 2019 at 8:11 AM
    #43
    2JZ_Tacupra
    Antoine
    Houston
    Picked up the 40 inch Maxxis tires this weekend!
    QMEDJoe, jubei, yota243 and 2 others like this.
  4. Sep 30, 2019 at 8:48 AM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I want to see some off-road burn outs!
  5. Sep 30, 2019 at 12:15 PM
    #45
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    :mudding:
  6. Sep 30, 2019 at 2:21 PM
    #46
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Just checked the actual video from on YT and he did some burn outs at the end.
    :burnrubber:
  7. Sep 30, 2019 at 3:33 PM
    #47
    2JZ_Tacupra
    Antoine
    Houston
    Yeah with the original setup there is some donuts and maybe a burnout in this video. We'll see how reckless I'll feel with 40" tires though...
  8. Sep 30, 2019 at 3:40 PM
    #48
    2JZ_Tacupra
    Antoine
    Houston
    Tatts521, Torspd and Plkyone like this.
  9. Oct 14, 2019 at 4:44 PM
    #49
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Dylan from FB, insta sub'd
  10. Oct 14, 2019 at 8:33 PM
    #50
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @2JZ_Tacupra WOW, I'm always impressed with the things TW members do with their Rigs. I'm an old man, and you make me feel stupid. Please keep a running total of expenses for this build, I'd be curious to know what your final price tag is on the investments. but when you get done, 1 of a kind badasssss Tacupra. Your obviously a really smart dude, what are you, a Nasa Rocket Engineer. I'm happy when I can keep my stock 2003 running and driving okay. :D
  11. Oct 17, 2019 at 8:31 AM
    #51
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How is the build coming along?
  12. Oct 22, 2019 at 1:35 PM
    #52
    2JZ_Tacupra
    Antoine
    Houston
    I probably have most of the invoices and receipts for parts, but given that I sourced some used components and I don't log labor I couldn't provide anyone a useful total cost estimate. Will do my best at some point to put some numbers together, but it's pretty low on my list of priorities. Honestly it would provide me with more pain than pleasure realizing my true out of pocket cost for this project.
    Wannabe NASA engineer. When I was 13 I was a finalist in the worlds largest rocketry competition called TARC. What I learned there definitely translates well to this type of work.
    It is really just a matter of money right now. Saving up for coilovers and bumpstops (possibly bypass shocks too)! Those will be costly so it may take some time.
    Torspd[QUOTED] likes this.
  13. Oct 22, 2019 at 1:39 PM
    #53
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those components are definitely an expense. Carry on man. I'll be patiently awaiting future updates!
  14. Oct 23, 2019 at 12:55 AM
    #54
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Sweet build!! I'd heard about this swap before but never really looked into it.
    I do have a question though, being as the 2j is from a sports car, how does it perform as a truck engine? I feel like truck tasks like towing, low speed grunt, and loading the bed with heavy things and hauling it hundreds of miles would hurt the 2j. I totally get the 2j is capable of like 700hp stock but that doesn't necessarily mean it has what's deseriable in a truck motor. I'm thinking like how the old GM LS engines were used in the Corvette and the Silverado. The Silverado had lower power ratings on paper but that Vortec engine with the cast iron block was rock solid being used as a truck engine. I'm not sure how a vette engine would fair towing a trailer up a steep grade. There was a reason GM engineers did what they did.
    Either way I'm always stoked to see custom builds like this! Keep up the great work. Can't wait for the twin turbo 1600hp build ;)
  15. Oct 23, 2019 at 6:00 AM
    #55
    2JZ_Tacupra
    Antoine
    Houston
    That's a good question and it all comes down to components and configuration. The 2JZ in its stock form is a very responsive engine as Yamaha and Toyota gave it a sequential turbo system. I could have gone with much more budget friendly parts but I wanted to keep it responsive. The EFR line of borgwarner turbos are spiffy with a super low interia rotating assembly from a titanium alloy turbine wheel, ballbearing, twin scroll. All features that contribute to low lag. A quick spool valve added to this effect. Short intake plumbing to minimize the volume the turbo had to compress. A water to air intercooler to minimize pressure drop. I think you get the idea. I was building boost at 2k rpm and had full 20 psi at 3k rpm. My decision to go compound is to retain my low end torque and maintain the torque all the way to redline with the primary turbo augmenting the top end flow the small turbo turbo was incapable of doing my itself.
    TLDR it has more torque at any rpm than the 5VZ. It's a great truck engine and you don't have to cherry pick data points it's just superior along the full rpm band. It's an overbuilt inline 6. More main bearings and a solid block. Only time will tell if it is up to the task.
    After trails at Lonestar Toyota Jamboree.
    Thousands of miles running errands (moved from the country into Houston only using the Tacoma and trailer)
  16. Oct 23, 2019 at 6:17 AM
    #56
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I was about to point out that the new supra has 400 ft/lb of torque and it hits peak at 1600 rpms and pulls through till red line.
  17. Oct 23, 2019 at 6:35 AM
    #57
    tony2018
    tony2018 Well-Known Member
    What ecu did you use? Curious because in Austin we have to pass inspection with the obd2 port being read.
  18. Oct 23, 2019 at 6:45 AM
    #58
    tony2018
    No need to answer, I just read back a couple pages. Can you give me the ecu code/part # so I can verify mine?
  19. Oct 23, 2019 at 7:01 AM
    #59
    2JZ_Tacupra
    Antoine
    Houston
    I am traveling for work at the moment so I can't be certain. But, it was an OBDII twin turbo 6spd manual ECU. Most likely 89661-14790
  20. Oct 23, 2019 at 9:06 AM
    #60
    ForestRunnerFrank99
    Josh
    Very interesting. So I guess it all comes down to the tune and turbo setup. Pretty cool! If I ever have a free $20k floating around I would definitely do the swap haha.
