2jz swap 07 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by limitedlifted, Sep 20, 2017.
  1. Sep 22, 2017 at 10:47 AM
    Miami Chillin
    Miami Chillin Well-Known Member
    DCLB TRD Sport 4x4
    Very nice. Im only aware of one other 2nd gen 2jz in Dubai. Always dreamed of this swap when I had my XRunner. Where are you located?
    limitedlifted[OP] likes this.
  2. Sep 22, 2017 at 10:50 AM
    limitedlifted
    limitedlifted [OP] Well-Known Member
    Haha well this build has been on the low for a while. Sorry for not doing the typical step by step for you guys but I'm not always at the shop and the swap was done by my mechanic. But what I can offer you is the sweet rewards of the post build.
    tcjacado and Torspd[QUOTED] like this.
  3. Sep 22, 2017 at 10:53 AM
    limitedlifted
    Yes we know it was open. Good eye on you
    tcjacado, Jcyr and Torspd[QUOTED] like this.
  4. Sep 22, 2017 at 10:55 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    This is how they should come from the factory.
    I mean seriously, wth Toyota?!?! :p
    tcjacado, Bocsy44, Jcyr and 2 others like this.
  5. Sep 22, 2017 at 10:58 AM
    limitedlifted
    Oh wow wasn't aware. The vehicle is located in Guyana, South America. I however travel on business to there and from New York.
    Jcyr likes this.
  6. Sep 22, 2017 at 1:53 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Sick so sick you could start an epidemic
    tcjacado and boostedka like this.
  7. Sep 22, 2017 at 3:58 PM
    5amtaco93
    5amtaco93 Well-Known Member
    Sam
    South Bend, WA
    '11 base 4x4 5 speed
    I can't remember
    What rear end do you have in this bad boy?
    Jcyr likes this.
  8. Sep 22, 2017 at 5:52 PM
    limitedlifted
    Stock for now. Going to have to add LSD.
  9. Sep 22, 2017 at 5:55 PM
    limitedlifted
    Bad news. The $800 clutch that I thought would stand up to the turbo got burned to the bone. This is after driving it for I'd say roughly 40 minutes.. btw it was brand new when it was installed. Oh well looks like it's going to be twin disc.
    tcjacado and Jcyr like this.
  10. Sep 22, 2017 at 7:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well let the smoke out of that quickly....
  11. Sep 23, 2017 at 3:12 PM
    Miami Chillin
    DCLB TRD Sport 4x4
    Yeaa this guy does crazy builds. Very nice man. I was born in Venezuela. Came here a while ago.
  12. Sep 23, 2017 at 3:18 PM
    bendilzerian
    bendilzerian Well-Known Member
    Houston
    2015 DCSB White TRD Sport PreXrunner
    This Tacoma and Supra owner approves. Immensely. :thumbsup:
    What trans are you using? What's the specs on the motor?
    Torspd likes this.
  13. Sep 23, 2017 at 4:31 PM
    limitedlifted
    Thanks, r154 trans. As for the specs, your typical 2jzgte vvti 97 Supra.
    Miami Chillin likes this.
  14. Sep 23, 2017 at 6:28 PM
    bendilzerian
    Houston
    Oh awesome, just a single setup with supporting mods then? What's your power goal
  15. Sep 23, 2017 at 7:23 PM
    #35
    limitedlifted
    Yes single turbo only. Well this is going to be daily driven so between 400-500. Once some time has past, might upgrade a few things to take it up a notch :thumbsup:
    (P.s currently building a Starion to drag race with a 1jz)
  16. Oct 4, 2017 at 2:58 PM
    #36
    limitedlifted
  17. Oct 4, 2017 at 6:21 PM
    #37
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Take it easy for a bit, dude. Nice swap and build but those A/F ratios were going very high under boost. Might want to get that sorted out before you blow the motor. If you are on the stock tacoma fuel pump, that needs to be upgraded.
    You probably smoked the clutch because it wasnt broken in. Should break it in for at least a hundred miles of easy stop/go before you apply full power. Also, your tach is off.
    Sub'd for future updates.
    ChadsPride likes this.
  18. Oct 4, 2017 at 6:42 PM
    #38
    Rockdwg
    Rockdwg Well-Known Member
    Rapid City, South Dakota
    2008 Tacoma DCSB trd off road
    might be a dumb question but the r154 tranny bolts up to a tacoma transfer case?
  19. Oct 4, 2017 at 8:22 PM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sooooo, I need to ask again. After seeing the AFR's like the other member mentioned, I am curious. Was that an earlier video, taken right after the swap was completed but only recently edited and uploaded?
    I ask because in the introduction of the engine bay, I still see that PCV port on the valve cover still open creating a possible vacuum leak. Has that been capped or fixed yet?
    PapaBear likes this.
  20. Oct 4, 2017 at 8:47 PM
    #40
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    You are a crazy bastard. And I'm jealous.
