2jz swap questons
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sky59, May 16, 2023.
  1. May 16, 2023 at 6:05 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    hey everyone! I have a 2.4 auto 1998 ext cab and I'm swapping a 2jz-gte vvti with an automatic 3f310 transmission in my truck and I'm trying to figure out if I can fit the 3f310 and keep the stock driveshaft as well as the harness situation I have the harness for the motor and trans just need help tieing it in with the truck harness thanks in advance.
    Orange01tAcO likes this.
  2. May 16, 2023 at 6:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It is just repinning the 4th ECM plug which is in your cab harness. To the 2jz ECM inputs.
    You have the correct schematics for all the vehicles involved in the swap ?
    One wire at a time.
    I am sure the drive shaft front flange will need changed and the length adjusted.
  3. May 16, 2023 at 6:41 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    For your driveshaft needs talk to DriveshaftPro.
    Sky59[OP] likes this.
  4. May 16, 2023 at 7:07 PM
    02hilux
    Planet: EARTH
    Sky59[OP] and Orange01tAcO like this.
  5. May 16, 2023 at 7:37 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    I have a schematic just by a Google search but nothing in-depth do you happen to have any?
  6. May 16, 2023 at 10:56 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Where’d you manage to find that engine? That’s a swap I’m debating, though on my Datsun not my truck. Hard to find the GTE variant for a good price in the states.
    You’re gonna have a hell of a time wiring all that and integrating it into the Tacoma body harness, I’ll tell you that much.
    Sky59[OP] and Abeyancer like this.
  7. May 17, 2023 at 10:46 AM
    Orange01tAcO
    Orange01tAcO 2jz swapped 2001 tacoma
    Ephraim
    Beaver Utah
    2001 Orange 2jz swapped Tacoma
    2jz swapped, Manual swaped, Raptor lined and much more.
    So the wiring from the 2jz to the Tacoma may be doable but eventually you will be changing it over to a Haltec ecu. I don’t know what your budget is but I do not regret get Haltec harness and computer. The drive shaft is something that is really easy to take to a drive shaft shop and lengthen or shorten. You just have to bolt everything in place and measure it.
    Sky59[OP] and Robmonster117 like this.
  8. May 17, 2023 at 1:25 PM
    Bivouac
    Without knowing all the years involved i have no Idea .
    Hunt for Copies of Toyota`s Electrical Wiring Diagrams for all vehicles involved
    Perhaps digital copies or hard copies.
    Buy time on All Data down load everything you need.
    Or Toyota TIS system your going to pay for what you need.
    All part of doing any swap I have all this before I touch anything and Have the engine to be swapped in on the stand.
    You might find someone to build what you need but it will not come cheap.
    Good luck your going to need it.
    Sky59[QUOTED][OP] likes this.
  9. May 17, 2023 at 1:28 PM
    Bivouac
    At this point going After market might be the OP`s best option .
    Once and done less chance of more mistakes.
    thanks for your input.
  10. May 17, 2023 at 2:09 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    From what I’ve researched, you can get the block/ bottom end out of any car with the GE and put a GTE head & components on it. Its pricey but you can still buy an OEM GTE head from Toyota. Depending on the power you are chasing, the block can be modified to install oil squirters (standard on GTE blocks). Im told by people much more versed in the JZ than I, its not critical unless 5-600+ hp is the goal.
  11. Jun 13, 2023 at 8:35 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    I got it in an online auction but definitely wasn't cheap either. hope it won't be too bad since the engine is the same year and still a Toyota it should be fairly simple to transfer diagrams from one another in theory lol
  12. Jun 13, 2023 at 8:36 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    willing to pay for a quality product ill look into it thanks.
    Orange01tAcO[QUOTED] likes this.
  13. Jun 16, 2023 at 4:04 AM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    You spent the money on a 2jz so you must be serious, talk to these people, Tweak’d Performance, look them up on internet you will find them. They wire up 2jz to fit in just about anything, they also do 1uz, their hobbies are drift cars, they can be tough to get ahold of, keep trying, tell them your goals and they will recommend a course of action. Spend some time dealing with two 25yr old engine harnesses, broken plastic connectors, corroded wires and factory computers with burnt capacitors and you'll get a better understanding.
    R/
    Andy
    Bivouac likes this.
