2K at 60MPH
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pengowirr, May 12, 2022.
  1. May 12, 2022 at 9:50 PM
    Pengowirr
    Pengowirr [OP] Well-Known Member
    2018 TRD Off Road Manual Transmission Cement
    265/75/r16 Cooper ST MAXX
    Give or take a couple MPH, this is my usual rpm’s when cruising on the interstate. Is it not too much? Is something wrong with my engine? Or is this perfectly normal.
    I drive an MT and though I know the gearing is different, I honestly don’t understand it much.
    i have 265/75 E rated tires, are they the culprit? I don’t remember what my stock tires got at 60mph
  2. May 12, 2022 at 9:59 PM
    papito3kids
    papito3kids Well-Known Member
    Patrick
    Colorado Springs
    2020 TRD Sport AC/6MT Cement, 23 4Runner Limited Classic Silver
    That's where I am at 60 rpm wise. I am NOT cruising on the interstate at that speed though! Someone's gonna hit you hard from behind. The manual is geared lower than the automatic models. Actually puts the engine in a happier place at highway speeds. 75 mph is about 2500 rpm. Use it!
  3. May 12, 2022 at 10:20 PM
    KOG89
    KOG89 Well-Known Member
    Castroville C.A
    09 DCSB 4x4 6spd manual
    Ome 2.5 lift front and rear, 886 coils on 9k nitrochargers with hd rear leaf springs. Ko2s on level 8 mk6 wheels. Prinsu roof rack , Bakflip tonneau cover
    Seems about the right rpm for that speed. I don't think you'd have to worry about your tires slowing you down too much for their current size maybe If they were bigger like 33's or 35's, and if you had additional weight on your truck. Then that's when you would maybe start questioning the rpms and start thinking about regearing.
  4. May 12, 2022 at 10:28 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Study this chart a bit, it might help give you a better understanding about the gearing.
  5. May 12, 2022 at 10:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I doubt it. Guy who asks this question will have no use for this chart. I.e., understand this chart, and you wouldn’t ask the question.
  6. May 12, 2022 at 10:37 PM
    TireFire
    Olympic Peninsula
    Stock tires are smaller which means your RPM would have been higher. It’s just simple math
  7. May 13, 2022 at 3:42 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Yep. I’m around the same with 265/75/16s.
    I would love a longer/wider spaced 5th and 6th gear. They are too close imo. I would rather have to downshift to pass in hurry than be at 2500 at 75.
  8. May 13, 2022 at 3:44 AM
    JackJoachim
    Jack
    North MS/Memphis
    So what you are telling me is that you basically have to go 35s with a manual?? Lol
  9. May 13, 2022 at 4:41 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Everyone has to start at the beginning, admitting that you don't understand something and asking a question is the first step to start learning.
    For those of us who may know some answers it then becomes our responsibility to teach and encourage.
  10. May 13, 2022 at 7:25 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    With the automatic trans, its 1600 at 60 mph, so with the axle ratio the manual has, 2k sounds normal.
  11. May 13, 2022 at 7:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are you satisfied with your fuel economy though? The overall gearing is nearly perfect for this truck. AT folks plopping in 5.29s are getting the very same 2k at 60.
    Of note, our Mazda 3 6AT turns about the same revs as the Taco in top gear. Our long gone Volvo 5MT used to turn 3k at 70mph.
  12. May 13, 2022 at 9:05 AM
    TireFire
    Olympic Peninsula
    And then you’ll be lugging the engine. This ain’t a high torque V8. Don’t be scared of RPMs.
    davidstacoma and HiBillyMaysHere like this.
  13. May 13, 2022 at 9:17 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just sayin', but I cruise in 6th at 35 quite a lot. Pulls gentle grades smoothly and will accelerate.
  14. May 13, 2022 at 9:20 AM
    TireFire
    Olympic Peninsula
    I don’t even know why this must be said but here it goes: engine load at 35mph is much less than freeway speeds.
    Edit: and you can think of engine load as torque demand
  15. May 13, 2022 at 9:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It doesn't as it is obvious, but the Taco is just fine in the range that I noted.
  16. May 13, 2022 at 9:22 AM
    TireFire
    Olympic Peninsula
    Did you read the title of the thread tho?
  17. May 13, 2022 at 9:30 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    LOL at "happier place" is that a technical term?
    My Auto 3.5 most efficient cruise is around 1600 rpm (60 mph) and the best acceleration seems to occurs around 5000 rpm so I'm not real sure about your happier place comment.
  18. May 13, 2022 at 9:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I know what this thread is about and replying to your assertion that 6th at 35 is not good.
    And, oops! I read the quote that you replied to as 35mph not 35s. Sorry!
  19. May 13, 2022 at 9:34 AM
    Pengowirr
    So my biggest question was if this type of employee was good for the engine. I know it’s ok to rev it and it won’t brake. But this puts it in a different light. I usually do 70. But I noticed that at 60 it’s at 2K. I thought it was supposed to be lower.
    I see, thanks. I’ll be doing 33s at some point. I was just wondering if this rpm was normal for my configuration.
    I’ve seen it but I honestly don’t get it. But I’ll save it and look into it. I’m sure I’ll grasp it eventually.
    So smaller tires = over 2K at 60 MPH? Interesting, I thought smaller tires would equal lower rpms
    yeah I think the 6th gear isn’t “tall” enough. But mostly my issue is reverse. It’s too damn fast! If that makes sense.
    Good point.
    Ahhh. So I imagine guys on 5.29 would be even higher rpms at 60MPH.
    “Satisfied” is a very flexible word. I would say I am satisfied for backroad driving. Being also that I’m lifted and it’s a heavy ish truck.
    For the highway? At 70+MPH I got 17-18. I feel that’s underwhelming but not a deal breaker of course. I still love this truck and it’s plenty fast on the highway with the MT.
  20. May 13, 2022 at 9:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm barely lifted, with a Softopper, and some weight. I get the same MPGs at those speeds. Overall, I'm just shy of 20 so far.
    The Taco is brick in the wind.
