2k mile maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jypwlkr1545, Apr 19, 2009.
  1. Apr 19, 2009 at 9:28 PM
    jypwlkr1545
    jypwlkr1545 [OP] Member
    08 white double door trd sport
    Just wanted any feedback on what maintenance should be done for my truck. Its got a little over 2k miles. Anyone who can help, thanks!
  2. Apr 19, 2009 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Fill with recomended gasoline. Drive. :)
  3. Apr 20, 2009 at 4:15 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    X2 :d
  4. Apr 20, 2009 at 4:41 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I read somewhere that Toyota recommends replacing the engine and transmission every 2,000 miles...
  5. Apr 20, 2009 at 5:49 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    That's what the manual says, I talked to a guy that stayed at a Holiday Inn Express once, you can push it to 3,000 to 4,000 if you get the blinker fluid flush at the 2,000 mile service.
  6. Apr 20, 2009 at 6:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your thinking of the Ford manuals....:)
  7. Apr 20, 2009 at 6:13 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    2016 4Runner 4x4 Limited Metallic Gray
    5K LED interior lighting
    Well with all the *GREAT* advice offered so far.. I would just advise you to follow your owner's manual. 5000 mi / 6 mo oil changes.. and there is a detailed maintenance guideline by mileage in your owners book.
  8. Apr 20, 2009 at 6:14 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    2k mile mantinace usually requires you get new elves under the hood, As well as a new troll under the rear differential change. By 2k they are usually tired and hungry.
  9. Apr 20, 2009 at 7:13 AM
    fletch aka
    Gary
    Left Coast
    In the Ford manual, there is an entire chapter on how to re-torque the bed bolts. From what I understand not even the factory has read that chapter, any input on that Chris? :D
  10. Apr 20, 2009 at 7:19 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Couple suggestions..
    I drained my oil at 500 miles and went to synthetic.
    OTHER TO DOs:
    Check tire pressure,
    Check windshield washer fluid
    Put do not steal hose clamp on tailgate.
    Check how tight the spare tire is on...
    Burn out carb a couple of times :)
  11. Apr 20, 2009 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking they havent. :(
  12. Apr 20, 2009 at 3:39 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'd change the oil if you haven't already, cheap Insurance. In prehistoric times you would change oil after the first 500 miles, now they (Toyota) says 5000 but I always do maintenance before mfg schedule, I'm in for the long run.
