2k RPM rattle right of instrument cluster.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacOto, Apr 28, 2019.
  1. Apr 28, 2019 at 12:14 PM
    TacOto
    TacOto [OP] Active Member
    2018 Cement Tacoma TRD Off Road
    So, I searched for this and couldn't find anything obvious.
    There are tons are "rattle at 2k RPM from engine bay" but this is definitely not that.
    When accelerating from 1900-2200 roughly there is a rattle / buzz from right of the instrument cluster. I took off the dash cover and if I pull the upper part of the vent tubing (closest to instrument cluster, left of radio) forward it goes away; but once I let it go it comes back.
    I have tried wedging cloths all over the place but it doesn't stop it. I also took out the radio and got access to the ventilator tubing as it travels back and did some poking around but nothing super obvious. Attempting a single wedge area but it made no difference.
    This is slowly driving me crazy. Every time i accelerate past 2k it happens. Goes away above 2200rpm.
    Any thoughts???
    Please!
  2. Apr 28, 2019 at 2:36 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    have you
  3. Apr 28, 2019 at 5:45 PM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Check your cabin air filter door. Found mine was not seated properly resulting in rattle. Take out your service manual and tray. Reseat the cabin air filter door. Go for a ride...see if rattle is gone! Cheers!:cheers:
  4. Apr 29, 2019 at 10:57 AM
    TacOto
    I have pushed all over the dash in a million places. No dice; it is definitely behind. I took off the front dash and drove around and the only thing that helped was pulling on the upper part of the ventilation tubing. go figure.
    I will check the cabin air filter! thanks!
  5. Apr 29, 2019 at 11:26 AM
    Clingman
    Clingman Well-Known Member
    17 Inferno TRDOR DCSB
    Mine did that and it was the fastener that holds the driver's side foot vent tube in place. It was not run in all the way and had a washer ratlling on it. Get your head down by the brake pedal and look straight up. It is up in there above a big wiring loom.
  6. Apr 29, 2019 at 11:34 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    It’s the turbo booster kicking in after you hit 2K RPM’s
  7. Apr 29, 2019 at 1:49 PM
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    I'm gonna guess it has to do with your air intake hose near the wheel wells. Heard those could rattle if not seated properly. Air sucks differently at 2K?
  8. Apr 29, 2019 at 4:53 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    Time to super glue everything.
