2lo in a taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Jul 30, 2009.
  1. Aug 4, 2009 at 8:04 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    okay well im looking to buy a 1st gen 2000-04 so even if its the TRD or the SR5 it will still be non locking hubs?
  2. Aug 4, 2009 at 8:13 PM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    you will have automatic locking hubs. All front hubs are locking. thats what gives you 4wd. the question is whether the vacuum system does it automatically via the ADD switch or whether you have to actually get out of the truck and turn a switch on the hub (inside wheel)
    if you can see the switch in the middle of the front wheel where the rim center cap should be, that is where the manual hub is locked. on a tacoma with automatic hubs, the center cap would just cover the hub and it would not matter.
    While auto hubs are easier and more convenient for 4wd on the fly, they are also more expensive to replace/fix and are not as strong as manual hubs, especially in an off road setting. Aisan is OEM for toyota in the manual hub department, and they make the best hubs out there i believe.
    hope it helped and anyone correct me if i am wrong on anything...
  3. Aug 4, 2009 at 8:49 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    okay well i just didnt word that right i meant non manual locking hubs. okay thanks all.
  4. Aug 4, 2009 at 9:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    2000's have manual hubs. 2001 and newer have auto locking hubs.
  5. Aug 5, 2009 at 5:15 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    My 2000 has Auto hubs! and Auto hubs are just as strong as a Manual hub. there's nothing to break in in an Auto hub except for the Half Axel it self.
